no way to compare when less than two revisions
— | artikel:nav_nx:releasenotes_sp53 [Sat. 12.01.2019 13:44] (aktuell) – angelegt go4it | ||
+ | ====== Releasenote des Service Pack 5.3 ====== | ||
+ | - Destination can not be entered using the seven-digit postcode (UK only) | ||
+ | - Resetting during operation | ||
+ | - Navigations/ | ||
+ | - Missing Audio/ | ||
+ | - Voice service can not be activated even after repeated pressing the PTT button | ||
+ | - Unit is in navigation mode for several minutes while the pop-up window appears < | ||
+ | - Unit is in navigation mode for several minutes while the use of a disclaimer <The Zielführung...> | ||
+ | - Unit is on the lists for the target input / target selection | ||
+ | - Stuck in the speech device operation for several minutes while the pop-up window appears < | ||
+ | - Unit is facing Tunnel Transit / Parking garage on over a long period, the message <No GPS> | ||
+ | - Occasionally, | ||
+ | - Volume can not be changed | ||
+ | - CD / AUX button does not work | ||
+ | - After starting the device displays only a blue screen | ||
+ | - Empty / grayed softkeys, although these would be activated | ||
+ | - Device hangs when running from a USB / iPod / Aux audio sources | ||
+ | - No iPod / USB device | ||
+ | - Pop-up window will <CD geprüft> | ||
+ | - Only Kuga 2008.5 with camera - parking aid: If you want the reverse gear is quickly shown a picture of the area behind the vehicle | ||
+ | - Only Galaxy 2006.5 with keypad - Additional Air Conditioning: | ||
+ | - Incorrect climate information in the status bar | ||
+ | - Personal settings (language, etc.) are lost | ||
+ | - Frequent resets in the operation | ||
+ | - Very short (<1 second) audio dropouts while playing music | ||
+ | - Deep and loud hum when playing audio sources (possibly only one channel) | ||
+ | - No navigation voice during telephone conversations | ||
+ | - Reset the navigation system with high number of traffic messages (TMC) | ||
+ | - After engine start audio system is again a different station | ||
+ | - (S-MAX/ | ||
