no way to compare when less than two revisions
Nächste Überarbeitung | |||
— | artikel:pdc:pam-module:pam_pinout [Sat. 26.10.2019 19:44] – angelegt go4it | ||
+ | ====== Anschlüsse und Steckerbelegungen ====== | ||
+ | {{artikel: | ||
+ | === Stecker " | ||
+ | * Pins: 16-polig, 2-reihig | ||
+ | * Steckertyp: Tyco 1534101-1, schwarz | ||
+ | * Steckerkappe: | ||
+ | {{artikel: | ||
+ | ^ Pin ^ Kabelfarbe ^ Funktion ^ | ||
+ | | 1 | BU | +12V über KL15 (Zündungsplus) | | ||
+ | | 2 | BU/GN | REAR SOUNDER - | | ||
+ | | 3 | | ||
+ | | 4 | GN/BN | SWITCH PAS - (PARKASSIST-ACTIVATION-SWITCH). Schaltet gegen GND. | | ||
+ | | 5 | | ||
+ | | 6 | | ||
+ | | 7 | VT/OG | MS-CAN_LOW (-) | | ||
+ | | 8 | BK/BU | GND | | ||
+ | | 9 | | ||
+ | | 10 | BN/BU | REAR SOUNDER + (Lautsprecher für hintere Sensoren) | | ||
+ | | 11 | | ||
+ | | 12 | | ||
+ | | 13 | GN/BU | STATUS LED PAS + (PARKASSIST-ACTIVATION-SWITCH). Mit Widerstand gegen Masse. | | ||
+ | | 14 | GY/OG | MS-CAN_HIGH (+) | | ||
+ | | 15 | | ||
+ | | 16 | | ||
+ | Anschlüsse für den Parkleitassistenten (gibt es beim Mondeo MK4 nicht): | ||
+ | * SENSOR SIGNAL FSL (PSM) | ||
+ | * SENSOR SIGNAL FSR (PSM) | ||
+ | * SENSOR SIGNAL BSL (PSM) | ||
+ | * SENSOR SIGNAL BSR (PSM) | ||
+ | * Pins: 12-polig, 2-reihig | ||
+ | * Steckertyp: Tyco 1534100-1, schwarz | ||
+ | | 1 | YE/OG | SENSOR GND | | ||
+ | | 2 | VT/GY | SENSOR VBAT (+12V) | | ||
+ | | 3 | VT/OG | FRONT SOUNDER - | | ||
+ | | 4 | GY/BN | FRONT SOUNDER + (Lautsprecher für vordere Sensoren) | | ||
+ | | 5 | BU/GN | SENSOR SIGNAL FL (Front-Left) (Sensor vorne, fahrtrichtung links aussen [ * - - - ] ) | | ||
+ | | 6 | WH/BU | SENSOR SIGNAL FIL (Front-Inner-Left) (Sensor vorne, fahrtrichtung links innen [ - * - - ] ) | | ||
+ | | 7 | BU/GY | SENSOR SIGNAL FIR (Front-Inner-Right) (Sensor vorne, fahrtrichtung rechts innen [ - - * - ] ) | | ||
+ | | 8 | BU/OG | SENSOR SIGNAL FR (Front-Right) (Sensor vorne, fahrtrichtung rechts aussen [ - - - * ] ) | | ||
+ | | 9 | | ||
+ | | 10 | | ||
+ | | 11 | | ||
+ | | 12 | | ||
+ | | 1 | | ||
+ | | 2 | YE/GY | SENSOR SIGNAL RIR (Sensor hinten, fahrtrichtung rechts innen [ - - * - ] ) | | ||
+ | | 3 | WH/OG | SENSOR SIGNAL RIL (Sensor hinten, fahrtrichtung links innen [ - * - - ] ) | | ||
+ | | 4 | YE/OG | SENSOR SIGNAL RR (Sensor hinten, fahrtrichtung rechts aussen [ - - - * ] ) | | ||
+ | | 5 | YE/GN | SENSOR SIGNAL ROL (Sensor hinten, fahrtrichtung links aussen [ * - - - ] ) | | ||
+ | | 6 | | ||
+ | | 7 | | ||
+ | | 8 | GN/WH | SENSOR GND | | ||
+ | | 9 | | ||
+ | | 10 | | ||
+ | | 11 | BU/WH | SENSOR VBAT (+12V) | | ||
+ | | 12 | | ||
