artikel:aussenspiegel:steckerbelegungen [Sat. 14.03.2020 22:33] – [Stecker am Kabelbaum vom Spiegel kommend] go4it | artikel:aussenspiegel:steckerbelegungen [Fri. 10.06.2022 06:03] – [Version mit elektrischer Anklappfunktion und Memory (12-pol)] go4it | ||
Zeile 17: | Zeile 17: | ||
* Typennummer: | * Typennummer: | ||
* Pins: '' | * Pins: '' | ||
==== Basisversion (8- oder 12-pol) ==== | ==== Basisversion (8- oder 12-pol) ==== | ||
Zeile 26: | Zeile 27: | ||
| 5 | BK | MIRROR HEATER | | | | 5 | BK | MIRROR HEATER | | | ||
| 6 | GY | MIRROR GND | | | | 6 | GY | MIRROR GND | | | ||
- | | 7 | BN | SIDE TURN INDI | | | + | | 7 | BN | SIDE TURN INDI | **OPT:** Nur beim FL, mit Seitenblinkern im Spiegel- |
| 8 | VT | PUDDEL LAMP | | | | 8 | VT | PUDDEL LAMP | | | ||
| 9 | | | 9 | | ||
Zeile 38: | Zeile 39: | ||
| 1 | YE | MIRROR X | | | | 1 | YE | MIRROR X | | | ||
| 2 | BU | MIRROR X/Y | | | | 2 | BU | MIRROR X/Y | | | ||
- | | 3 | OG/GN | MIRROR Y/FOLD OUT | | | + | | 3 | OG+GN | MIRROR Y/FOLD OUT | | |
| 4 | RD | MIRROR FOLD | | | | 4 | RD | MIRROR FOLD | | | ||
| 9 | | | 9 | | ||
Zeile 53: | Zeile 54: | ||
- | ^ Pin ^ Kabelfarbe ^ Bezeichnung ^ Funktion ^ | + | ^ Pin ^ Kabelfarbe |
- | | 1 | YE | MIRROR X | | | + | | 1 | YE |
- | | 2 | BU | MIRROR X/Y | | | + | | 2 | BU |
- | | 3 | OG/GN | MIRROR Y/FOLD OUT | | | + | | 3 | OG+GN | 0,35 mm² | MIRROR Y/FOLD OUT | | |
- | | 4 | RD | MIRROR FOLD | | | + | | 4 | RD |
- | | 5 | BK | MIRROR HEATER | | | + | | 5 | BK |
- | | 6 | GY | + | | 6 | BK-YE | 0,35 mm² | MIRROR GND | | |
- | | 8 | VT | PUDDEL LAMP | | | + | | 8 | BN | 0,35 mm² | PUDDEL LAMP | | |
- | | 9 | YE/BU | MIRROR SENSOR INPUT X | | | + | | 9 | GY-BK | 0,35 mm² | MIRROR SENSOR INPUT X | | |
- | | 10 | BN/YE | MIRROR SENSOR INPUT Y | | | + | | 10 | BK-BU | 0,35 mm² | MIRROR SENSOR INPUT Y | | |
- | | 11 | GY/VT | MIRROR SENSOR SUPPLY | | | + | | 11 | VT |
- | | 12 | YE | MIRROR SENSOR GND | | | + | | 12 | BN-YE | 0,35 mm² | MIRROR SENSOR GND | | |
===== BLIS-LED ===== | ===== BLIS-LED ===== | ||
Zeile 71: | Zeile 72: | ||
=== Stecker vom Spiegelkabelbaum kommend (3-pol) === | === Stecker vom Spiegelkabelbaum kommend (3-pol) === | ||
* Hersteller: Delphi (jetzt " | * Hersteller: Delphi (jetzt " | ||
* Passende Crimp-Stifte (Weiblich): '' | * Passende Crimp-Stifte (Weiblich): '' | ||
+ | **Fahrerseitig (LH):** | ||
- | | 1 | RD-BK | LED SIGNAL | | | + | | 1 | GN-WH | LED SIGNAL | | |
- | | 2 | BK-WH | LED GND | | | + | | 2 | GY-VT | LED GND | | |
- | | 3 | | + | | 3 | - | - | | |
+ | **Beifahrerseitig (RH):** | ||
+ | | 1 | BN | LED SIGNAL | | | ||
+ | | 2 | YE-VT | LED GND | | | ||
+ | | 3 | | ||
=== Stecker am Ende des Spiegelkabelbaums (2-pol) === | === Stecker am Ende des Spiegelkabelbaums (2-pol) === | ||
* Hersteller: JST | * Hersteller: JST | ||
Zeile 91: | Zeile 101: | ||
* Pin/ | * Pin/ | ||
* Kabeltypen: AWG 26-22 (0,13-0,33 mm²) | * Kabeltypen: AWG 26-22 (0,13-0,33 mm²) | ||
- | === Buchse von LED-Kabelstück | + | **Beifahrerseitig |
- | {{: | + | ^ Pin ^ Kabelfarbe ^ Bezeichnung ^ Funktion ^ |
+ | | 2 | YE-VT | LED GND | | ||
+ | === Von BLIS-LED am Spiegel bis Übergangsbuchse | ||
* Modellreihe: | * Modellreihe: | ||
* Buchse: 02T-JWPF-VSLE-S | * Buchse: 02T-JWPF-VSLE-S | ||
* Pin/Buchse: SWPT-001T-P025 (Männlich) | * Pin/Buchse: SWPT-001T-P025 (Männlich) | ||
+ | | 1 | GY | LED SIGNAL | | | ||
+ | | 2 | BN | LED GND | | | ||
