artikel:einparkhilfe:rvc-modul [Tue. 09.04.2019 04:49] – [Interner Aufbau] go4it | artikel:einparkhilfe:rvc-modul [Sun. 26.01.2020 11:02] – go4it | ||
Zeile 17: | Zeile 17: | ||
- | * 9M2J-19H405-AD | + | |
- | * 9M2J-19H405-AC | + | |
+ | * 9M2J-19H405-AC | ||
+ | * Focus: | ||
+ | * 8M5J-18K405-AA | ||
+ | ==== Pinbelegung Versorgungsstecker (C1, Grün) ==== | ||
+ | | 1 | | - | - | | ||
+ | | 2 | | - | - | | ||
+ | | 3 | | - | - | | ||
+ | | 4 | | - | - | | ||
+ | | 5 | | GND | GND Stromversorgung (:i: Im Mondeo nicht belegen!) | | ||
+ | | 6 | BU | IGN | 12V Stromversorgung nach Zündung an | | ||
+ | | 7 | | - | - | | ||
+ | | 8 | | - | - | | ||
+ | | 9 | | - | - | | ||
+ | | 10 | | - | - | | ||
+ | | 11 | | - | - | | ||
+ | | 12 | | - | - | | ||
+ | | 13 | VT/OG | MS-CAN_LO | MS-CAN Bus | | ||
+ | | 14 | GY/OG | MS-CAN_HI | MS-CAN Bus | | ||
+ | | 15 | | GND | GND Stromversorgung (:i: Im Mondeo nicht belegen!) | | ||
+ | | 16 | | - | - | | ||
+ | | 5 | | - | - | | ||
+ | | 6 | | - | - | | ||
- | | + | ==== Oberseite ==== |
+ | ==== Unterseite ==== | ||
+ | * Spansion Flash S29JL032H70TFA01 | ||
+ | * LVDS Deserializer MAX9218 (27-Bit, 3-35 MHz) | ||
+ | * BSP742R (Label " | ||
+ | * 24,545 MHz Quarz | ||
+ | * TJA1040 CAN-Transceiver | ||
+ | * ADV7179 - BU.656 Digital zu Analog PAL/NTSC Video Encoder | ||
+ | * NXP1021T20 (=TJA1021) LIN Tranceiver | ||
+ | * LTC3407EMSE (Label " | ||
+ | * ATtiny 4313 (Label " |
