artikel:einparkhilfe:rvc-modul [Tue. 09.04.2019 04:54] – [Interner Aufbau] go4it | artikel:einparkhilfe:rvc-modul [Sun. 03.05.2020 09:16] – go4it | ||
Zeile 5: | Zeile 5: | ||
Zeile 15: | Zeile 15: | ||
- | * 9M2J-19H405-AD | ||
- | * 9M2J-19H405-AC | ||
Zeile 24: | Zeile 20: | ||
+ | ==== Pinbelegung Versorgungsstecker (C1, Grün) ==== | ||
- | ===== Interner Aufbau ===== | + | {{: |
- | Bauteile: | + | * Hersteller: JAE |
+ | * Modell: IL-AG5-16 | ||
- | | + | ^ Pin ^ Kabelfarbe ^ Bezeichnung ^ Funktion ^ |
- | | + | | 2 | | - | - | |
- | * Spansion Flash S29JL032H70TFA01 | + | | 3 | | - | - | |
- | * LVDS Deserializer MAX9218 (27-Bit, 3-35 MHz) | + | | 4 | | - | - | |
- | * BSP742R | + | | 5 | | GND | GND Stromversorgung (:i: Im Mondeo nicht belegen!) | |
+ | | 6 | BU | IGN | 12V Stromversorgung nach Zündung an | | ||
+ | | 7 | | - | - | | ||
+ | | 8 | | - | - | | ||
+ | | 9 | | - | - | | ||
+ | | 10 | | ||
+ | | 11 | | - | - | | ||
+ | | 12 | | - | - | | ||
+ | | 13 | VT/OG | MS-CAN_LO | MS-CAN Bus | | ||
+ | | 14 | GY/OG | MS-CAN_HI | MS-CAN Bus | | ||
+ | | 15 | | GND | GND Stromversorgung | ||
+ | | 16 | | - | - | | ||
+ | ==== Pinbelegung, Kamerastecker (C3, Silber) ==== | ||
+ | * Hersteller: Molex | ||
+ | * Serie: 53460 | ||
+ | * Modell: [[https:// | ||
+ | | 2 | | - | - | | ||
+ | | 3 | | ||
+ | | 5 | | - | - | | ||
+ | | 6 | | - | - | | ||
+ | Hirose GT5-2S-HU | ||
+ | | 1 | | - | - | | ||
+ | ===== Bauteile ===== | ||
- | * " | + | ^ Part ^ Marking |
- | * NXP1021T20 | + | | '' |
