artikel:einparkhilfe:rvc-modul [Sun. 06.10.2019 14:51] – go4it | artikel:einparkhilfe:rvc-modul [Mon. 13.04.2020 11:14] – [Bauteile] go4it | ||
Zeile 5: | Zeile 5: | ||
Zeile 15: | Zeile 15: | ||
- | * 9M2J-19H405-AD | ||
- | * 9M2J-19H405-AC | ||
Zeile 24: | Zeile 20: | ||
+ | * Hersteller: JAE | ||
+ | * Modell: IL-AG5-16 | ||
Zeile 33: | Zeile 32: | ||
- | | 5 | | + | | 5 | |
Zeile 43: | Zeile 42: | ||
- | | 15 | | + | | 15 | |
- | ===== Interner Aufbau ===== | + | ==== Pinbelegung, |
- | Bauteile: | + | {{:artikel: |
- | * [[M9CS12DG128CFUE]] | + | * Hersteller: Molex |
- | * ADW95079-05 | + | * Typ: 2.00mm Pitch IEEE 1394-1995 Shielded I/O PCB Socket |
- | * RAM Micron 48LC4M32B2 (1M x 32 x 4 Banks, PC100, 4 Meg x 32) | + | * Serie: 53460 |
- | * Spansion Flash S29JL032H70TFA01 | + | * Modell: [[https:// |
- | * LVDS Deserializer MAX9218 (27-Bit, 3-35 MHz) | + | |
- | * BSP742R | + | ^ Pin ^ Kabelfarbe ^ Bezeichnung ^ Funktion ^ |
+ | | 2 | | - | - | | ||
+ | | 3 | | - | - | | ||
+ | | 5 | | - | - | | ||
+ | | 6 | | - | - | | ||
+ | | 1 | | - | - | | ||
+ | ==== Debug-Port (A) for M9CS12 ==== | ||
+ | ===== Bauteile ===== | ||
- | | + | ^ Part ^ Marking |
- | * ADV7179 | + | | '' |
- | * NXP1021T20 | + | | '' |
