artikel:ipc:mac7116 [Mon. 01.04.2019 04:13] – [Init procedure] go4it | artikel:ipc:mac7116 [Thu. 18.07.2019 05:20] – [Unsecure Chip] go4it | ||
Zeile 13: | Zeile 13: | ||
* Quartz: 8 MHz | * Quartz: 8 MHz | ||
* Program Flash: 1 MByte | * Program Flash: 1 MByte | ||
- | * Data Flash: | + | * Data Flash: |
- | * SRAM: 32 KByte | + | * SRAM: 48 KByte |
* Datenblatt: [[https:// | * Datenblatt: [[https:// | ||
Zeile 41: | Zeile 41: | ||
^ Periphal ^ Base-Addr ^ End-Addr ^ Size ^ | ^ Periphal ^ Base-Addr ^ End-Addr ^ Size ^ | ||
| Program Flash | 0x0000 0000 | 0x000F FFFF | 0x10 0000 (1 mb) | | | Program Flash | 0x0000 0000 | 0x000F FFFF | 0x10 0000 (1 mb) | | ||
- | | Data Flash | 0xFE00 0000 | | (48 kb) | | + | | Data Flash | 0xFE00 0000 | | (32 kb) | |
- | | SRAM | 0x4000 0000 | 0x4000 7FFF | 0x8000 (32 kb) | | + | | SRAM | 0x4000 0000 | 0x4000 7FFF | 0x8000 (48 kb) | |
progflash base 0xfc100000 | progflash base 0xfc100000 | ||
Zeile 483: | Zeile 483: | ||
+ | ===== Unsecure Chip ===== | ||
+ | - set MCU mode using the MOD(A|B) | ||
+ | - set Oscillator type | ||
+ | - set External bus interface attributes | ||
+ | - set Nexus port attributes | ||
+ | - issue JTAG unlock procedure | ||
+ | - Erase the program and data flash | ||
+ | - Write new content to program flash | ||
+ | ==== Set MCU mode ==== | ||
+ | Signals of MODA and MODB pins (PD[1:0]) are latched on rising edge of /RESET signal. |
