artikel:ipc:mac7116
Nächste Überarbeitung
artikel:ipc:mac7116 [Thu. 18.07.2019 05:20] – [Unsecure Chip] go4itartikel:ipc:mac7116 [Wed. 10.11.2021 19:35] – [MAC7116 MCU] go4it
Zeile 1: Zeile 1:
 ====== MAC7116 MCU ====== ====== MAC7116 MCU ======
-===== Data =====+{{:artikel:ipc:mac7116_on_pcb.jpg?direct&320|}} {{:artikel:ipc:mac7116_pinout.png?direct&420|}}
 +===== Markings =====
-  * Bauteileschriftung: ''NXP MAC7116VAG50'' +  ''MAC7116'' = Product
-  * Gehäuse: 144LQFP +  - ''V'' = Temperature range -40°C to +105°C
-  * Core: ARM7TDMI-S: +  - ''AG'' = LQFP-144 Package
-    * 32 Bit Big-Endian +  ''50'' = Core Speed 50 MHz
-    * ARMv4 Instruction-Set +  - ''L38Y'' = Mask Set "Fully-qualified, production"
-    * 50 MHz +
-    * 8kb unified cache +
-    * Memory Management Unit (MMU) +
-  * Quartz: 8 MHz +
-  * Program Flash: 1 MByte +
-  * Data Flash: 32 KByte +
-  * SRAM: 48 KByte +
-  * Datenblatt: [[https://www.nxp.com/part/MAC7116VAG50]]+
-{{:artikel:ipc:mac7116_pinout.png?direct|}}
-==== Bootstrap ====+===== Specifications =====
-=== Chip operation mode ===+  * 1 MByte of Program Flash
 +  * 32 KByte of Data Flash
 +  * 48 KBytes of SRAM
 +  * External Bus
 +  * 1x ATD Module A (AD-Converter with 16 Channels and 8/10-bit resolution)
 +  * 4x CAN Modules (A, B, C and D)
 +  * 4x eSCI Modules (A, B, C and D)
 +  * 2x DSPI Modules (A and B)
 +  * I2C Module
 +  * eMIOS Module, 16 channels, 16-bit
 +  * Timer Module, 10 channels, 24-bit
 +  * 112 GPIO Ports (Total)
-The chip operating mode is determined by the states of the MODA (Pin 71) and MODB (Pin 70) pins at reset and the security status of the program Flash.+===== Operating =====
 +==== Bootstrap ====
-{{:artikel:ipc:convers_vfl_mcu-area_explained.jpg?direct&400|}}+As of the wirering of MODA and MODB pins, the chip is running in "Normal Single Chip Mode". This means:
-^ MODA ^ MODB ^ Program Flash secured ^ Chip mode ^ Description ^ +  All debug features available (JTAG, for example)
-|  0  |  0  |  No  | Normal Single-Chip Mode | Boots from internal flash | +  — The chips boots from program Flash
- 0  |  1  |  No  | Normal Expanded Mode | Boots from external flash | +
-|  1  |  0  |  No  | Normal Data Flash Boot Mode | Boots from data flash | +
-|  0  |  0  |  Yes  | Secured Single-Chip Mode | Boots from internal flash | +
-|  0  |  1  |  Yes  | Secured Expanded Mode | Boots from external flash | +
-|  1  |  0  |  Yes  | Secured Data Flash Boot Mode | Boots from data flash | +
-|  1  |  1  |  -  | -RESERVED - |+
 === Memory Map === === Memory Map ===
Zeile 483: Zeile 482:
 </code> </code>
-===== Unsecure Chip =====
-  - set MCU mode using the MOD(A|B)
-  - set Oscillator type
-  - set External bus interface attributes
-  - set Nexus port attributes
-  - issue JTAG unlock procedure
-  - Erase the program and data flash
-  - Write new content to program flash
-==== Set MCU mode ====
-Signals of MODA and  MODB pins (PD[1:0]) are latched on rising edge of /RESET signal.
  • artikel/ipc/mac7116.txt
  • Zuletzt geändert: Thu. 11.11.2021 07:32
  • von go4it
