artikel:ipc:mac7116 [Mon. 01.04.2019 04:13] – [Init procedure] go4it | artikel:ipc:mac7116 [Wed. 10.11.2021 19:35] – [MAC7116 MCU] go4it | ||
- | ===== Data ===== | + | {{: |
+ | ===== Markings | ||
- | * 32 Bit Big-Endian | + | - '' |
- | * ARMv4 Instruction-Set | + | |
- | * 50 MHz | + | |
- | * 8kb unified cache | + | |
- | * Memory Management Unit (MMU) | + | |
- | * Program Flash: 1 MByte | + | |
- | * Data Flash: 48 KByte | + | |
- | * SRAM: 32 KByte | + | |
- | * Datenblatt: [[https:// | + | |
- | ==== Bootstrap | + | ===== Specifications ===== |
- | === Chip operation mode === | + | * 1 MByte of Program Flash |
+ | * 32 KByte of Data Flash | ||
+ | * 48 KBytes of SRAM | ||
+ | * External Bus | ||
+ | * 1x ATD Module A (AD-Converter with 16 Channels and 8/10-bit resolution) | ||
+ | * 4x CAN Modules (A, B, C and D) | ||
+ | * 4x eSCI Modules (A, B, C and D) | ||
+ | * 2x DSPI Modules (A and B) | ||
+ | * I2C Module | ||
+ | * eMIOS Module, 16 channels, 16-bit | ||
+ | * Timer Module, 10 channels, 24-bit | ||
+ | * 112 GPIO Ports (Total) | ||
- | The chip operating mode is determined by the states of the MODA (Pin 71) and MODB (Pin 70) pins at reset and the security status of the program Flash. | + | ===== Operating ===== |
+ | ==== Bootstrap ==== | ||
- | {{:artikel: | + | As of the wirering of MODA and MODB pins, the chip is running in " |
- | ^ MODA ^ MODB ^ Program Flash secured ^ Chip mode ^ Description ^ | + | |
- | | 0 | 0 | No | Normal Single-Chip Mode | Boots from internal flash | | + | |
- | | 0 | 1 | No | Normal Expanded Mode | Boots from external flash | | + | |
- | | 1 | 0 | No | Normal Data Flash Boot Mode | Boots from data flash | | + | |
- | | 0 | 0 | Yes | Secured Single-Chip Mode | Boots from internal flash | | + | |
- | | 0 | 1 | Yes | Secured Expanded Mode | Boots from external flash | | + | |
- | | 1 | 0 | Yes | Secured Data Flash Boot Mode | Boots from data flash | | + | |
- | | 1 | 1 | - | -RESERVED - | | + | |
=== Memory Map === | === Memory Map === | ||
Zeile 41: | Zeile 40: | ||
^ Periphal ^ Base-Addr ^ End-Addr ^ Size ^ | ^ Periphal ^ Base-Addr ^ End-Addr ^ Size ^ | ||
| Program Flash | 0x0000 0000 | 0x000F FFFF | 0x10 0000 (1 mb) | | | Program Flash | 0x0000 0000 | 0x000F FFFF | 0x10 0000 (1 mb) | | ||
- | | Data Flash | 0xFE00 0000 | | (48 kb) | | + | | Data Flash | 0xFE00 0000 | | (32 kb) | |
- | | SRAM | 0x4000 0000 | 0x4000 7FFF | 0x8000 (32 kb) | | + | | SRAM | 0x4000 0000 | 0x4000 7FFF | 0x8000 (48 kb) | |
progflash base 0xfc100000 | progflash base 0xfc100000 | ||
Zeile 482: | Zeile 481: | ||
; mass erase does erase program and data flash. | ; mass erase does erase program and data flash. | ||
