artikel:ipc:mac7116 [Thu. 18.07.2019 05:20] – [Unsecure Chip] go4it | artikel:ipc:mac7116 [Thu. 18.07.2019 18:22] – go4it | ||
- | ===== Data ===== | + | ===== MCU ===== |
* Bauteileschriftung: | * Bauteileschriftung: | ||
Zeile 7: | Zeile 7: | ||
* Core: ARM7TDMI-S: | * Core: ARM7TDMI-S: | ||
* 32 Bit Big-Endian | * 32 Bit Big-Endian | ||
- | * ARMv4 Instruction-Set | + | * ARMv4T |
- | * 50 MHz | + | * 50 MHz Clock |
* 8kb unified cache | * 8kb unified cache | ||
* Memory Management Unit (MMU) | * Memory Management Unit (MMU) | ||
+ | * EmbeddedICE macrocell consists of on-chip logic to support debug operations via JTAG-Interface | ||
* Quartz: 8 MHz | * Quartz: 8 MHz | ||
* Program Flash: 1 MByte | * Program Flash: 1 MByte | ||
Zeile 483: | Zeile 484: | ||
- | ===== Unsecure Chip ===== | ||
- | - set MCU mode using the MOD(A|B) | ||
- | - set Oscillator type | ||
- | - set External bus interface attributes | ||
- | - set Nexus port attributes | ||
- | - issue JTAG unlock procedure | ||
- | - Erase the program and data flash | ||
- | - Write new content to program flash | ||
- | ==== Set MCU mode ==== | ||
- | Signals of MODA and MODB pins (PD[1:0]) are latched on rising edge of /RESET signal. |
