artikel:ipc:service-menue [Sun. 25.11.2018 10:49] – ↷ Seite von grundlagen:ipc:service-menue nach artikel:ipc:service-menue verschoben wikiadmin | artikel:ipc:service-menue [Sun. 12.07.2020 07:10] – wikiadmin | ||
Zeile 15: | Zeile 15: | ||
- Fill in all lcd illumination | - Fill in all lcd illumination | ||
- Light up all warning indication LED's | - Light up all warning indication LED's | ||
- | - ROM Leve; Displays the instrument memory ROM, Cluster ROM level and type | + | - ROM Level - Displays the instruments firmware version |
- | - Non-Volatile Memory Level, Displays the instrument cluster | + | - Non-Volatile Memory Level - Displays the instrument cluster |
- Not Required - EEXXFAIL Checksum Fault? | - Not Required - EEXXFAIL Checksum Fault? | ||
- Not required - CF1XX Configuration | - Not required - CF1XX Configuration |
