artikel:nav_fx:pin_code_decryptor
Nächste Überarbeitung
Letzte ÜberarbeitungBeide Seiten der Revision
artikel:nav_fx:pin_code_decryptor [Fri. 20.09.2019 19:21] go4itartikel:nav_fx:pin_code_decryptor [Thu. 31.10.2019 23:14] go4it
Zeile 4: Zeile 4:
 {{:artikel:nav_fx:navi-fx_typenschild.jpg?nolink|}} {{:artikel:nav_fx:navi-fx_typenschild.jpg?nolink|}}
-:!: **AKTUELL WERDEN NUR CODES DES "A05" ALGORITHMUS BERECHNET**
 <html> <html>
Zeile 21: Zeile 19:
     </td>     </td>
     <td>     <td>
-      <input type="text" name="type" id="type" minlength="10" maxlength="10" ><br/> +      <input type="text" name="type" id="type" minlength="10" maxlength="13" ><br/>
-      <div style="font-size: 0.8em; color:#A0A0A0;">Example: 7612300524</div>+      <div style="font-size: 0.8em; color:#A0A0A0;">Example: 7 612 300 524</div>
     </td>     </td>
    </tr>    </tr>
Zeile 46: Zeile 44:
 <script> <script>
 jQuery('#btn_calc').click(function(event){ jQuery('#btn_calc').click(function(event){
-  if(jQuery('#type').val().substr(7,1) != '5') { +  jQuery('#pin_code').load('https://mk4-wiki.denkdose.de/tools/satnav/calc_pin.php?type='encodeURIComponent(jQuery('#type').val()) + "&serial="encodeURIComponent(jQuery('#serial').val()), function(responseText, status) {
-    alert('This type cannot be calculated (see notes above form)'); +
-    return false; +
-  jQuery('#pin_code').load('https://mk4-wiki.denkdose.de/tools/satnav/calc_pin.php?type='+jQuery('#type').val()+"&serial="+jQuery('#serial').val(), function(responseText, status) {+
     var data = jQuery.parseJSON(responseText);     var data = jQuery.parseJSON(responseText);
     if (data['result'] == 'OK') {     if (data['result'] == 'OK') {
       jQuery('#pin_code').val(data['data']);       jQuery('#pin_code').val(data['data']);
-    } else {+    } else if (data['result'] == 'ERROR'{
       jQuery('#pin_code').val('----');       jQuery('#pin_code').val('----');
 +      alert(data['message']);
Zeile 61: Zeile 56:
 </script> </script>
 </html> </html>
