artikel:nav_mca:videoeingang_nachruesten
Nächste Überarbeitung
artikel:nav_mca:videoeingang_nachruesten [Tue. 21.07.2020 22:40] – [Teile] go4itartikel:nav_mca:videoeingang_nachruesten [Sun. 28.08.2022 09:09] (aktuell) – [Teile] wikiadmin
Zeile 36: Zeile 36:
 | 4 | Capacitor | 100 pF | 0402 |  |  |  | | 4 | Capacitor | 100 pF | 0402 |  |  |  |
 | 2 | Capacitor | 15 pF | 0402 |  |  |  | | 2 | Capacitor | 15 pF | 0402 |  |  |  |
-| 2 | Capacitor | 15 pf | 0402 |  |  |  |
 | 1 | Capacitor | 47 pF | 0402 |  | 50V | 0,01 | | 1 | Capacitor | 47 pF | 0402 |  | 50V | 0,01 |
 | 1 | Capacitor | 470 nF | 0805 |  | 25V | 0,1 | | 1 | Capacitor | 470 nF | 0805 |  | 25V | 0,1 |
Zeile 59: Zeile 58:
 | 1 | Resistor | 470 Ohm | 0402 |  | 63 mW | 0,01 | | 1 | Resistor | 470 Ohm | 0402 |  | 63 mW | 0,01 |
 | 1 | Resistor | 56 Ohm | 0402 |  | 63 mW | 0,01 | | 1 | Resistor | 56 Ohm | 0402 |  | 63 mW | 0,01 |
-| Resistor array (4x 0402) | 4x 33 Ohm | 0805 | 330 | 63 mW | 0,05 | +| Resistor array (4x 0402) | 4x 33 Ohm | 0402 | 330 | 63 mW | 0,05 |
-| 1 | Resistor array (4x 0402) | 4x 33 Ohm | 0805 | 330 | 63 mW | 0,05 |+
 | 1 | Diode | BAV99 | SOT-23 | A7 | 80V/0,2A |  | | 1 | Diode | BAV99 | SOT-23 | A7 | 80V/0,2A |  |
 | 1 | NPN Transistor | BC847CW | SOT323 | 1Gs | 45V/0,2A |  | | 1 | NPN Transistor | BC847CW | SOT323 | 1Gs | 45V/0,2A |  |
 | 1 | 28,63636 MHz Quarz (18 pF) | ABM8G-28.63636MHZ-18-D2Y-T | 3.2 x 2.5 mm |  |  |  | | 1 | 28,63636 MHz Quarz (18 pF) | ABM8G-28.63636MHZ-18-D2Y-T | 3.2 x 2.5 mm |  |  |  |
-| 1 | Video A/D converter | ADV7181C BSTZ | LQFP-64 |  |  |  |+| 1 | Video A/D converter | ADV7181B-BSTZ oder ADV7181C-BSTZ | LQFP-64 |  |  |  |
 | 1 | Operational amplifier | LMH6601QMG | SOT323-6 | AKA |  |  | | 1 | Operational amplifier | LMH6601QMG | SOT323-6 | AKA |  |  |
 | 1 | 1.8V LDO voltage regulator | MAX8880EUT+T | SOT23-6 | AAHR |  |  | | 1 | 1.8V LDO voltage regulator | MAX8880EUT+T | SOT23-6 | AAHR |  |  |
Zeile 73: Zeile 71:
 | 1 | SMP-Socket, solder, SMD, 50 Ω | Rosenberger 19S101-40ML5 |  |  |  |  | | 1 | SMP-Socket, solder, SMD, 50 Ω | Rosenberger 19S101-40ML5 |  |  |  |  |
-:!: //Beim ADV unbedingt darauf achten das es ein ADV7181__C__ ist und kein ADV7181__B__, weil dieses Vorgängermodell ein {{:artikel:nav_mca:diff_adv7181c_and_adv7181b.png?linkonly|völlig anderes Pinout}} hat.//+:i: //Beim ADV7181 ist es egal ob man das Original verbaute Modell "B" oder das Nachfolgemodell "C" verwendet. Obgleich das "C" ein anderes Pinout hat (siehe {{:artikel:nav_mca:diff_adv7181c_and_adv7181b.png?linkonly|Pinout-Vergleich Version "B" und "C"}}) scheint Analog Devices diese doch kompatibel gestaltet zu haben. In all meinen Nachrüsten konnte ich beide jedenfalls wechselweise ohne Probleme verwenden.//
 ==== Werkzeuge und Hilfsmittel ==== ==== Werkzeuge und Hilfsmittel ====
Zeile 248: Zeile 246:
   * 1x 4,7 µF (1206)   * 1x 4,7 µF (1206)
   * 1x 10 µF (1206)   * 1x 10 µF (1206)
-  * 2x BLM18AG (0805)+  * 2x BLM18AG (0603)
   * 1x LMH6601 (SOT323-6)   * 1x LMH6601 (SOT323-6)
   * 1x MAX8880 (SOT23-6)   * 1x MAX8880 (SOT23-6)
Zeile 358: Zeile 356:
 Anstelle der FAKRA-I Buchse, wie sie im Original verwendet wird, kann man natürlich auch jede andere Buchse seiner Wahl einbauen. Kameras aus dem Zubehörhandel verwenden z.B. überwiegend einen gelben Cinch-Stecker (RCA) und man müsste dann noch einen Adapter auf FAKRA dazu kaufen. Zudem sind die passenden, beigen FAKRA-Buchsen extrem schwer zu beschaffen. Anstelle der FAKRA-I Buchse, wie sie im Original verwendet wird, kann man natürlich auch jede andere Buchse seiner Wahl einbauen. Kameras aus dem Zubehörhandel verwenden z.B. überwiegend einen gelben Cinch-Stecker (RCA) und man müsste dann noch einen Adapter auf FAKRA dazu kaufen. Zudem sind die passenden, beigen FAKRA-Buchsen extrem schwer zu beschaffen.
-Hier zeige ich also eine Variante mit einer handelsüblichen Cinch-Buchse. Diese gibt es unisoliert:+Hier zeige ich also eine Variante mit einer handelsüblichen Cinch-Buchse:
 {{:artikel:nav_mca:cinch_buchse.jpg?direct&200|}} {{:artikel:nav_mca:cinch_buchse.jpg?direct&200|}}
-aber auch mit Isolierung:
-{{:artikel:nav_mca:cinch_buchse_isoliert.jpg?direct&200|}}
-**In jedem Fall muss die Buchse so eingebaut werden, das zwischen Buchsen-Aussenring (Video-Masse) und Gehäuse keine elektrische Verbindung entsteht!**
-Bei einer nicht isolierten Buchse kann man sich mit einer Plastikhülse um das Gewinde und Plastik-Unterlegscheiben vor und hinter dem Montageblech behelfen.
 Damit die Cinch-Buchse durch passt muss das vorhandene Loch aufgebohrt werden. Hierbei besonders darauf achten das keine Späne oder feiner Metallabrieb vom anschließenden Grat-Entfernen auf die Platine fallen! Damit die Cinch-Buchse durch passt muss das vorhandene Loch aufgebohrt werden. Hierbei besonders darauf achten das keine Späne oder feiner Metallabrieb vom anschließenden Grat-Entfernen auf die Platine fallen!
Zeile 375: Zeile 365:
 {{:artikel:nav_mca:img_4441.jpg?direct&400|}} {{:artikel:nav_mca:img_4441.jpg?direct&400|}}
-{{:artikel:nav_mca:img_4442.jpg?direct&400|}}
-{{:artikel:nav_mca:img_4443.jpg?direct&400|}}
 {{:artikel:nav_mca:mca_video-port_cinch_mounted.jpg?direct&400|}} {{:artikel:nav_mca:mca_video-port_cinch_mounted.jpg?direct&400|}}
  • artikel/nav_mca/videoeingang_nachruesten.txt
  • Zuletzt geändert: Sun. 28.08.2022 09:09
  • von wikiadmin
