artikel:pdc:pam-module:start [Sat. 26.10.2019 19:44] – [Aus- Einbau] go4it | artikel:pdc:pam-module:start [Sat. 26.10.2019 19:46] – go4it | ||
Zeile 15: | Zeile 15: | ||
* [[pam_pinout]] | * [[pam_pinout]] | ||
+ | * [[firmware_disassemble]] | ||
- | ===== Anschlüsse und Steckerbelegungen ===== | ||
- | {{artikel: | ||
- | === Stecker " | ||
- | * Pins: 16-polig, 2-reihig | ||
- | * Steckertyp: Tyco 1534101-1, schwarz | ||
- | * Steckerkappe: | ||
- | {{artikel: | ||
- | ^ Pin ^ Kabelfarbe ^ Funktion ^ | ||
- | | 1 | BU | +12V über KL15 (Zündungsplus) | | ||
- | | 2 | BU/GN | REAR SOUNDER - | | ||
- | | 3 | | ||
- | | 4 | GN/BN | SWITCH PAS - (PARKASSIST-ACTIVATION-SWITCH). Schaltet gegen GND. | | ||
- | | 5 | | ||
- | | 6 | | ||
- | | 7 | VT/OG | MS-CAN_LOW (-) | | ||
- | | 8 | BK/BU | GND | | ||
- | | 9 | | ||
- | | 10 | BN/BU | REAR SOUNDER + (Lautsprecher für hintere Sensoren) | | ||
- | | 11 | | ||
- | | 12 | | ||
- | | 13 | GN/BU | STATUS LED PAS + (PARKASSIST-ACTIVATION-SWITCH). Mit Widerstand gegen Masse. | | ||
- | | 14 | GY/OG | MS-CAN_HIGH (+) | | ||
- | | 15 | | ||
- | | 16 | | ||
- | Anschlüsse für den Parkleitassistenten (gibt es beim Mondeo MK4 nicht): | ||
- | * SENSOR SIGNAL FSL (PSM) | ||
- | * SENSOR SIGNAL FSR (PSM) | ||
- | * SENSOR SIGNAL BSL (PSM) | ||
- | * SENSOR SIGNAL BSR (PSM) | ||
- | * Pins: 12-polig, 2-reihig | ||
- | * Steckertyp: Tyco 1534100-1, schwarz | ||
- | | 1 | YE/OG | SENSOR GND | | ||
- | | 2 | VT/GY | SENSOR VBAT (+12V) | | ||
- | | 3 | VT/OG | FRONT SOUNDER - | | ||
- | | 4 | GY/BN | FRONT SOUNDER + (Lautsprecher für vordere Sensoren) | | ||
- | | 5 | BU/GN | SENSOR SIGNAL FL (Front-Left) (Sensor vorne, fahrtrichtung links aussen [ * - - - ] ) | | ||
- | | 6 | WH/BU | SENSOR SIGNAL FIL (Front-Inner-Left) (Sensor vorne, fahrtrichtung links innen [ - * - - ] ) | | ||
- | | 7 | BU/GY | SENSOR SIGNAL FIR (Front-Inner-Right) (Sensor vorne, fahrtrichtung rechts innen [ - - * - ] ) | | ||
- | | 8 | BU/OG | SENSOR SIGNAL FR (Front-Right) (Sensor vorne, fahrtrichtung rechts aussen [ - - - * ] ) | | ||
- | | 9 | | ||
- | | 10 | | ||
- | | 11 | | ||
- | | 12 | | ||
- | | 1 | | ||
- | | 2 | YE/GY | SENSOR SIGNAL RIR (Sensor hinten, fahrtrichtung rechts innen [ - - * - ] ) | | ||
- | | 3 | WH/OG | SENSOR SIGNAL RIL (Sensor hinten, fahrtrichtung links innen [ - * - - ] ) | | ||
- | | 4 | YE/OG | SENSOR SIGNAL RR (Sensor hinten, fahrtrichtung rechts aussen [ - - - * ] ) | | ||
- | | 5 | YE/GN | SENSOR SIGNAL ROL (Sensor hinten, fahrtrichtung links aussen [ * - - - ] ) | | ||
- | | 6 | | ||
- | | 7 | | ||
- | | 8 | GN/WH | SENSOR GND | | ||
- | | 9 | | ||
- | | 10 | | ||
- | | 11 | BU/WH | SENSOR VBAT (+12V) | | ||
- | | 12 | | ||
- | ===== Innenleben des PAM ===== | ||
- | {{artikel: | ||
- | * MC9S12DG128CFUE - NXP Microcontroller ({{artikel: | ||
- | * 25 MHz, 16-Bit, 3x CAN-Controller (CAN 2.0 A/B), 128 KB Flash, 8 KB RAM, 2 KB EEPROM, 59x GPIO, 1x I2C, 8-Kanal, 10-Bit A/D Wandler, 8-Kanal, 8-Bit PWM, 7-Kanal, 16-Bit Timer, 2x SPI, 2x SCI, ... | ||
- | * TJA1040 - High-Speed CAN-Tranceiver | ||
- | * TLE4263 - Infineon Low-Drop Spannungsregler | ||
- | * LM2904 - Low-power dual operational amplifier | ||
- | Im betriebsbereiten Zustand verbraucht das System ca. 50 mA. Bei der Initialisierung sind es kurzfristig ca. 80 mA und im aktiven Zustand (inkl. LED und Lautsprecher) ca. 200 mA. | ||
- | ====== Firmware Disassemble mit IDA Pro ====== | ||
- | Einstellungen: | ||
- | - Processor type: '' | ||
- | - Processor options => Edit ARM architecture options: '' | ||
