artikel:bcm:pinbelegung_c1_vfl [Sat. 09.07.2022 15:54] – go4it | artikel:bcm:pinbelegung_c1_vfl [Sat. 09.07.2022 16:27] (aktuell) – go4it | ||
{{tag> | {{tag> | ||
- | ====== Stecker " | + | ====== Stecker " |
- | ==Bilder== | ||
- | ==Infos== | ||
In den elektrischen Schaltplänen wird der Steckerverbinder " | In den elektrischen Schaltplänen wird der Steckerverbinder " | ||
- | ==Pinbelegung== | + | ===== Pinbelegung ===== |
- | ^ Pin ^ Kabelfarbe ^ Funktion (Plan) ^ Beschreibung ^ | + | |
- | | 1 | YE/VT | TURN INDICATOR FRONT RIGHT SUPPLY | | | + | |
- | | 2 | | | | + | |
- | | 3 | | | | + | |
- | | 4 | | | | + | |
- | | 5 | | SPARE | | + | |
- | | 6 | | | | + | |
- | | 7 | | | | + | |
- | | 8 | | SPARE | | + | |
- | | 9 | | | | + | |
- | | 10 | | | | + | |
- | | 11 | | | | + | |
- | | 12 | | | | + | |
- | | 13 | | COOLANT LEVEL SWITCH | | + | |
- | | 14 | | | | + | |
- | | 15 | | | | + | |
- | | 16 | | SPEED OUTPUT | | + | |
- | | 17 | | AUXILIARY LIGHTS RELAY LOGIC | | + | |
- | | 18 | | AMBIENT TEMPERATURE SENSOR | | + | |
- | | 19 | BU/GN | TURN INDICATOR FRONT LEFT SUPPLY | | + | |
- | | 20 | | SPARE | | + | |
- | | 21 | BU/BN | TPMS RF SIGNAL | | + | |
- | | 22 | BN/WH | TPMS RF GND | | + | |
- | | 23 | | | | + | |
- | | 24 | | | | + | |
- | | 25 | VT | WASHER FLUID LEVEL SWITCH | | + | |
- | | 26 | BU | REVERSE GEAR SWITCH | | + | |
- | | 27 | GY/VT | BRAKE FLUID LEVEL SWITCH | | + | |
- | | 28 | VT/GN | COMFORT FRONT/FAN RELAY LOGIC | | + | |
- | | 29 | BN/BU | FRONT WIPER PARK POS. SW | | + | |
- | | 30 | VT/OG | WINDSCREEN HEATING/2ND BATTERY LOGIC | | + | |
- | | 31 | BN/WH | ??? | | + | |
- | | 32 | GN/BN | E-HL CLEAN 2 LOGIC | | + | |
- | | 33 | VT/BN | TPMS LF SIGNAL | | + | |
- | | 34 | YE | TPMS LF GND | | + | |
- | | 35 | | LIN0 (SECURITY) | | + | |
- | | 36 | | LIN2 (SMART WIPER) | | + | |
- | | 37 | GN/BU | STOP LAMP SW SIG | | + | |
- | | 38 | | | | + | |
- | | 39 | YE/BU | POS. LIGHT FRONT LEFT SUPPLY | | + | |
- | | 40 | BN/YE | POS LIGHT FRONT RIGHT SUPPLY | | + | |
- | | 41 | BN/WH | FRONT WIPER RELAY HI/LO/E-HL CLEAN 4 | | + | |
- | | 42 | | | | + | |
- | | 43 | WH | FRONT WIPER RELAY ON/OFF LOGIC | | + | |
- | | 44 | VT/OG | ECM WAKE UP SUPPLY | | + | |
- | | 45 | GN/VT | KL15 RELAY LOGIC | | + | |
- | | 46 | YT/GN | HORN RELAY LOGIC | | + | |
- | | 47 | YE/GN | HEADLAMP WASHER RELAY LOGIC | | + | |
- | | 48 | BU/GY | | | + | |
- | | 49 | GY/OG | MS CAN HIGH | | + | |
- | | 50 | VT/OG | MS CAN LOW | | + | |
- | | 51 | | CLUTCH PEDAL SENSOR SUPPLY | | + | |
- | | 52 | | CLUTCH PEDAL SENSOR | | + | |
- | | 53 | | CLUTCH PEDAL SENSOR GND | | + | |
- | | 54 | BK/GY | ELECTRONIC GND | | + | |
- | | 55 | GY | ABS 15 FEED | | + | |
- | | 56 | | SPARE | | + | |
- | | 57 | | SPARE | | + | |
- | | 58 | | SPARE | | + | |
- | | 59 | | SPARE | | + | |
- | | 60 | | SPARE | | + | |
- | | 61 | | SPARE | | + | |
- | | 62 | | SPARE | | + | |
- | | 63 | | SPARE | | + | |
- | | 64 | | SPARE | | + | |
- | | 65 | BU | KL15 RELAY SUPPLY EJB | | + | |
- | | 66 | | SPARE | | + | |
- | | 67 | | BAT. BACKUP SOUNDER SUPPLY | | + | |
- | | 68 | BN | FRONT FOG RIGHT SUPPLY | | + | |
- | | 69 | BN | FRONT FOG LEFT SUPPLY | | + | |
- | | 70 | | | | + | |
- | | 71 | GY | FRONT SCREEN WAHSER SUPPLY | | + | |
- | | 72 | VT/GN | REAR SCREEN WASHER SUPPLY | | + | |
- | | 73 | VT/OG | MAIN BEAM RIGHT SUPPLY | | + | |
- | | 74 | GY/BN | MAIN BEAM LEFT SUPPLY | | + | |
- | | 75 | BU/GN | DIPPED BEAM RIGHT SUPPLY | | + | |
- | | 76 | BN/BU | DIPPED BEAM LEFT SUPPLY | | + | |
+ | ^ Pin ^ Farbe ^ Typ ^ Bezeichnung | ||
+ | | 1 | YE-VT | 0,75 mm² | TURN INDICATOR FRONT RIGHT SUPPLY | | | ||
+ | | 2 | | | | | | ||
+ | | 3 | | | | | | ||
+ | | 4 | | | | | | ||
+ | | 5 | | | | | | ||
+ | | 6 | | | | | | ||
+ | | 7 | | | | | | ||
+ | | 8 | | | | | | ||
+ | | 9 | | | | | | ||
+ | | 10 | | | | | | ||
+ | | 11 | | | | | | ||
+ | | 12 | | | | | | ||
+ | | 13 | | | | | | ||
+ | | 14 | | | | | | ||
+ | | 15 | | | | | | ||
+ | | 16 | | | | | | ||
+ | | 17 | | | | | | ||
+ | | 18 | | | | | | ||
+ | | 19 | BU-GN | 0,75 mm² | TURN INDICATOR FRONT LEFT SUPPLY | | | ||
+ | | 20 | | | | | | ||
+ | | 21 | BU-BN | 0,75 mm² | TPMS RF SIGNAL | | | ||
+ | | 22 | BN-WH | 0,75 mm² | TPMS RF GND | | | ||
+ | | 23 | BU-OG | 0,50 mm² | HOOD AJAR SWITCH | | | ||
+ | | 24 | | | | | | ||
+ | | 25 | VT | 0,50 mm² | WASHER FLUID LEVEL SWITCH | | | ||
+ | | 26 | BU | 0,50 mm² | REVERSE GEAR SWITCH | | | ||
+ | | 27 | GY-VT | 0,50 mm² | BRAKE FLUID LEVEL SWITCH | | | ||
+ | | 28 | VT-GN | 0,50 mm² | COMFORT FRONT/FAN RELAY LOGIC | | | ||
+ | | 29 | BN-BU | 0,50 mm² | FRONT WIPER PARK POS. SW | | | ||
+ | | 30 | VT-OG | 0,50 mm² | WINDSCREEN HEATING/2ND BATTERY LOGIC | | | ||
+ | | 31 | BN-WH | 0,50 mm² | FUEL PUMP MONITOR | | | ||
+ | | 32 | GN-BN | 0,50 mm² | E-HL CLEAN 2 LOGIC | | | ||
+ | | 33 | VT-BN | 0,75 mm² | TPMS LF SIGNAL | | | ||
+ | | 34 | YE | 0,75 mm² | TPMS LF GND | | | ||
+ | | 35 | BN-BU | 0,75 mm² | LIN0 (SECURITY) | | | ||
+ | | 36 | YE-BU | 0,50 mm² | LIN2 (SMART WIPER) | | | ||
+ | | 37 | GN-BU | 0,50 mm² | STOP LAMP SW SIG | | | ||
+ | | 38 | | | | | | ||
+ | | 39 | YE-BU | 0,50 mm² | POS. LIGHT FRONT LEFT SUPPLY | | | ||
+ | | 40 | BN-YE | 0,50 mm² | POS LIGHT FRONT RIGHT SUPPLY | | | ||
+ | | 41 | BN-WH | 0,50 mm² | FRONT WIPER RELAY HI/LO/E-HL CLEAN 4 | | | ||
+ | | 42 | | | | | | ||
+ | | 43 | WH | 0,50 mm² | FRONT WIPER RELAY ON/OFF LOGIC | | | ||
+ | | 44 | VT-OG | 0,50 mm² | ECM WAKE UP SUPPLY | | | ||
+ | | 45 | GN-VT | 0,50 mm² | KL15 RELAY LOGIC | | | ||
+ | | 46 | YT-GN | 0,50 mm² | HORN RELAY LOGIC | | | ||
+ | | 47 | YE-GN | 0,50 mm² | HEADLAMP WASHER RELAY LOGIC | | | ||
+ | | 48 | BU-GY | 0,50 mm² | RH TURN LAMP | | | ||
+ | | 49 | GY-OG | 0,50 mm² | MS CAN HIGH | | | ||
+ | | 50 | VT-OG | 0,50 mm² | MS CAN LOW | | | ||
+ | | 51 | GN | 0,50 mm² | CLUTCH PEDAL SENSOR SUPPLY | | | ||
+ | | 52 | BN-GN | 0,50 mm² | CLUTCH PEDAL SENSOR | | | ||
+ | | 53 | WH-VT | 0,50 mm² | CLUTCH PEDAL SENSOR GND | | | ||
+ | | 54 | BK-GY | 0,75 mm² | ELECTRONIC GND | | | ||
+ | | 55 | GY | 0,75 mm² | ABS 15 FEED | | | ||
+ | | 56 | | | | | | ||
+ | | 57 | | | | | | ||
+ | | 58 | | | | | | ||
+ | | 59 | | | | | | ||
+ | | 60 | | | | | | ||
+ | | 61 | | | | | | ||
+ | | 62 | | | | | | ||
+ | | 63 | | | | | | ||
+ | | 64 | | | | | | ||
+ | | 65 | BU | 0,75 mm² | KL15 RELAY SUPPLY EJB | | | ||
+ | | 66 | | | | | | ||
+ | | 67 | YE-RD | 0,75 mm² | BAT. BACKUP SOUNDER SUPPLY | | | ||
+ | | 68 | BN | 1,00 mm² | FRONT FOG RIGHT SUPPLY | | | ||
+ | | 69 | BN | 1,00 mm² | FRONT FOG LEFT SUPPLY | | | ||
+ | | 70 | | | | | | ||
+ | | 71 | GY | 1,00 mm² | FRONT SCREEN WAHSER SUPPLY | | | ||
+ | | 72 | VT-GN | 1,00 mm² | REAR SCREEN WASHER SUPPLY | | | ||
+ | | 73 | VT-OG | 1,00 mm² | MAIN BEAM RIGHT SUPPLY | | | ||
+ | | 74 | GY-BN | 1,00 mm² | MAIN BEAM LEFT SUPPLY | | | ||
+ | | 75 | BU-GN | 1,00 mm² | DIPPED BEAM RIGHT SUPPLY | | | ||
+ | | 76 | BN-BU | 1,00 mm² | DIPPED BEAM LEFT SUPPLY | | | ||
