artikel:bcm:pinbelegung_c2_vfl [Sun. 25.11.2018 10:49] – ↷ Seite von grundlagen:bcm:pinbelegung_c2_vfl nach artikel:bcm:pinbelegung_c2_vfl verschoben wikiadmin | artikel:bcm:pinbelegung_c2_vfl [Sun. 04.10.2020 17:51] – go4it | ||
Zeile 4: | Zeile 4: | ||
//Kabelbaum Innenraum/ | //Kabelbaum Innenraum/ | ||
- | {{:grundlagen: | + | {{artikel: |
==Infos== | ==Infos== | ||
Zeile 14: | Zeile 14: | ||
^ Pin ^ Kabelfarbe ^ Querschnitt ^ Name ^ Funktion ^ | ^ Pin ^ Kabelfarbe ^ Querschnitt ^ Name ^ Funktion ^ | ||
- | | 1 | - | | | | | + | | 1 | GY-BN | | | KEY-IN SIGNAL TO EPB | |
- | | 2 | - | | | | | + | | 2 | BN-BU | | | REAR WINDOW DEFROSTER LOGIC | |
- | | 3 | - | | | | | + | | 3 | BN-GN | 0, |
- | | 4 | - | | | | | + | | 4 | GY-VT | 0, |
- | | 5 | - | | | | | + | | 5 | BU | | | 15 RJB RELAY LOGIC | |
- | | 6 | WH | 0,50mm² | | | | + | | 6 | | 0,50mm² | | | |
- | | 7 | GN-VT | 0,50mm² | | | | + | | 7 | | 0,50mm² | | | |
- | | 8 | YE | 0,50mm² | | | | + | | 8 | | 0,50mm² | | | |
- | | 9 | GN | 0,50mm² | | | | + | | 9 | YE-GY | 0,50mm² | | CHMSL SUPPLY |
- | | 10 | YE-OG | 0,50mm² | | | | + | | 10 | GN | 0,50mm² | | AJAR SW DOOR RL | |
- | | 11 | GN-BN | 0,50mm² | | | | + | | 11 | VT | 0,50mm² | | AJAR SW DOOR FL | |
- | | 12 | VT-WH | 0,50mm² | | | | + | | 12 | GY-OG | 0,50mm² | | REAR QUARTER WINDOW RELAY LOGIC | |
- | | 13 | BN | 0,50mm² | | | | + | | 13 | | 0,50mm² | | | |
- | | 14 | - | | | | | + | | 14 | | | | | |
- | | 15 | - | | | | | + | | 15 | BN-YE | 0, |
- | | 16 | - | | | | | + | | 16 | BU-OG | 0, |
- | | 17 | - | | | | | + | | 17 | | | | | |
- | | 18 | GN-OG | 0, | + | | 18 | | | | | |
- | | 19 | - | | | | | + | | 19 | | | | | |
- | | 20 | - | | | | | + | | 20 | | | | | |
- | | 21 | - | | | | | + | | 21 | WH-BU | | | REAR_DOOR_CENTRAL_LOCK_LOGIC |
- | | 22 | - | | | | | + | | 22 | BN-GN | | | | |
- | | 23 | - | | | | | + | | 23 | | | | | |
- | | 24 | - | | | | | + | | 24 | BN | | | TRUNK LIFTGATE RELEASE SW | |
- | | 25 | - | | | | | + | | 25 | YE-RD | | | LIN4 RF RECEIVER |
- | | 26 | BN-BU | 0,50mm² | | | | + | | 26 | VT-WH | 0,50mm² | | BRAKE DIAG SW | |
- | | 27 | - | | | | | + | | 27 | VT-WH | | | | |
- | | 28 | - | | | | | + | | 28 | YE | | | AJAR SW DOOR RR | |
- | | 29 | YE-OG | 0,50mm² | | | | + | | 29 | WH | 0,50mm² | | AJAR SW DOOR FR | |
- | | 30 | YE-VT | 0,75mm² | | | | + | | 30 | YE-OG | 0,75mm² | | AJAR SW TAILGATE |
- | | 31 | - | | | | | + | | 31 | | | | | |
- | | 32 | - | | | | | + | | 32 | | | | | |
- | | 33 | GN-YT | 0,50mm² | | | | + | | 33 | YE-VT | 0,50mm² | | FUEL TANK PUMP SENSOR |
- | | 34 | - | | | | | + | | 34 | YE-OG | | | ACC PEDAL SENSOR |
- | | 35 | - | | | | | + | | 35 | | | | | |
- | | 36 | GY-OG | 0, | + | | 36 | | | | | |
- | | 37 | - | | | | | + | | 37 | BN | | | SW ILLUMINATION |
- | | 38 | BN-GN | 0,75mm² | | | | + | | 38 | BN-GN | 0,75mm² | | REAR FOG LIGHT RIGHT | |
- | | 39 | BN-GN | 0,75mm² | | | | + | | 39 | BN-GN | 0,75mm² | | REAR FOG LIGHT LEFT | |
- | | 40 | - | | | | | + | | 40 | | | | | |
- | | 41 | - | | | | | + | | 41 | GN-VT | | | CLUTCH SWITCH 25% | |
- | | 42 | GY-BU | 0,50mm² | | | | + | | 42 | GY | 0,50mm² | | LIN BRIDGE KV | |
- | | 43 | - | | | | | + | | 43 | YE-OG | | | REAR DOOR CENTRAL DOUBLE LOCK LOGIC | |
- | | 44 | - | | | | | + | | 44 | GY-OG | | | TURN INDICATION REAR LEFT | |
- | | 45 | BU | 0,50mm² | | | | + | | 45 | GN-BU | 0,50mm² | | STOP LIGHT SWITCH INPUT | |
- | | 46 | - | | | | | + | | 46 | | | | | |
- | | 47 | VT-GN | 0,50mm² | | | | + | | 47 | | 0,50mm² | | | |
- | | 48 | GN-BU | 0,50mm² | | | | + | | 48 | YE-VT | 0,50mm² | | LICENSE PLATE LIGHT SUPPLY |
- | | 49 | YE-GY | 0,75mm² | | | | + | | 49 | VT-GN | 0,75mm² | | POSITION LIGHT REAR LEFT | |
- | | 50 | VT-GN | 0,75mm² | | | | + | | 50 | WH-OG | 0,75mm² | | POSITION LIGHT REAR RIGHT | |
- | | 51 | WH-OG | 0,75mm² | | | | + | | 51 | GN-BU | 0,75mm² | | FUEL TANK PUMP SNS GND | |
- | | 52 | YE-VT | 0,75mm² | | | | + | | 52 | VT-GN | 0,75mm² | | ACC PEDAL SENSOR GND | |
- | | 53 | - | | | | | + | | 53 | | | | | |
- | | 54 | GN-BU | 0,50mm² | | | | + | | 54 | BN | 0,50mm² | | | |
- | | 55 | - | | | | | + | | 55 | GN-RD | | | STOP LAMP SW SUPPLY |
- | | 56 | BN-GN | 1,00mm² | | | | + | | 56 | | 1,00mm² | | DAYTIME RUNNING LH | |
- | | 57 | - | | | | | + | | 57 | GY | | | DAYTIME RUNNING RH | |
- | | 58 | GY | 1,00mm² | | | | + | | 58 | VT | 1,00mm² | | ELECTRONIC 15 FEED | |
- | | 59 | VT | 1,00mm² | | | | + | | 59 | VT-BN | 1,00mm² | | STOP LIGHT LEFT/ |
- | | 60 | - | | | | | + | | 60 | VT-BN | | | | |
- | | 61 | - | | | | | + | | 61 | | | | | |
- | | 62 | GN-BN | 1,00mm² | | | | + | | 62 | WH-VT | 1,00mm² | | FUEL FLAP UNLOCK RELAY | |
- | | 63 | - | | | | | + | | 63 | YE-VT | | | TRUNK RELEASE |
- | | 64 | - | | | | | + | | 64 | | | | | |
- | | 65 | BK-GN | 1,50mm² | | | | + | | 65 | BK-GN | 1,50mm² | | POWER GND | |
- | | 66 | GN-BN | 0,50mm² | | | | + | | 66 | | 0,50mm² | | TURN INDICATOR FRONT RIGHT | |
- | | 67 | WH-VT | 0,50mm² | | | | + | | 67 | WH-VT | 0,50mm² | FUEL FLAP UNLOCK RELAY | | |
- | | 68 | GY-VT | 0,50mm² | | | | + | | 68 | GY-VT | 0,50mm² | | FUEL FLAP LOCK RELAY | |
- | | 69 | - | | | | | + | | 69 | GN-OG | | | TURN INDICATION REAR RIGHT | |
- | | 70 | - | | | | | + | | 70 | BN-GN | | | INTERIOR LIGHT | |
- | | 71 | YE-VT | 1, | + | | 71 | | | | | |
- | | 72 | - | | | | | + | | 72 | | | | | |
- | | 73 | GN-BN | 1,00mm² | | | | + | | 73 | GN-BN | 1,00mm² | | REVERSE LIGHT SUPPLY LEFT | |
- | | 74 | - | | | | | + | | 74 | GN-BN | | | REVERSE LIGHT SUPPLY RIGHT | |
- | | 75 | - | | | | | + | | 75 | | | | | |
- | | 76 | YE-OG | 1,50mm² | | | | + | | 76 | YE-OG | 1,50mm² | | KL15 RELAY SUPPLY EJB | |
