artikel:bcm:pinbelegung_c2_vfl [Sun. 15.09.2019 18:27] – go4it | artikel:bcm:pinbelegung_c2_vfl [Thu. 19.11.2020 18:08] (aktuell) – go4it | ||
Zeile 8: | Zeile 8: | ||
==Infos== | ==Infos== | ||
- | In den elektrischen Schaltplänen wird der Steckerverbinder " | + | In den elektrischen Schaltplänen wird der Steckerverbinder " |
==Pinbelegung== | ==Pinbelegung== | ||
Zeile 16: | Zeile 16: | ||
| 1 | GY-BN | | | KEY-IN SIGNAL TO EPB | | | 1 | GY-BN | | | KEY-IN SIGNAL TO EPB | | ||
| 2 | BN-BU | | | REAR WINDOW DEFROSTER LOGIC | | | 2 | BN-BU | | | REAR WINDOW DEFROSTER LOGIC | | ||
- | | 3 | | | | | | + | | 3 | BN-GN | 0, |
- | | 4 | GY-BU | | | REAR WIPER RELAY LOGIC | | + | | 4 | GY-VT | 0, |
| 5 | BU | | | 15 RJB RELAY LOGIC | | | 5 | BU | | | 15 RJB RELAY LOGIC | | ||
| 6 | | 0,50mm² | | | | | 6 | | 0,50mm² | | | | ||
Zeile 28: | Zeile 28: | ||
| 13 | | 0,50mm² | | | | | 13 | | 0,50mm² | | | | ||
| 14 | | | | | | | 14 | | | | | | ||
- | | 15 | GY-BU | | | EPB WARNING LAMP SW | | + | | 15 | BN-YE | 0, |
- | | 16 | GN-OG | | | ACC PEDAL SENSOR SUPPLY | + | | 16 | BU-OG | 0, |
| 17 | | | | | | | 17 | | | | | | ||
- | | 18 | | 0, | + | | 18 | | | | | |
- | | 19 | BN-GN | | | TPMS RR SIGNAL | + | | 19 | | | | | |
- | | 20 | GY-VT | | | TPMS RR GND | | + | | 20 | | | | | |
| 21 | WH-BU | | | REAR_DOOR_CENTRAL_LOCK_LOGIC | | | 21 | WH-BU | | | REAR_DOOR_CENTRAL_LOCK_LOGIC | | ||
| 22 | BN-GN | | | | | | 22 | BN-GN | | | | | ||
Zeile 48: | Zeile 48: | ||
| 33 | YE-VT | 0,50mm² | | FUEL TANK PUMP SENSOR | | | 33 | YE-VT | 0,50mm² | | FUEL TANK PUMP SENSOR | | ||
| 34 | YE-OG | | | ACC PEDAL SENSOR | | | 34 | YE-OG | | | ACC PEDAL SENSOR | | ||
- | | 35 | BU-OG | | | TPMS LR GND | | + | | 35 | | | | | |
- | | 36 | BN-YE | 0, | + | | 36 | | | | | |
| 37 | BN | | | SW ILLUMINATION | | | 37 | BN | | | SW ILLUMINATION | | ||
| 38 | BN-GN | 0,75mm² | | REAR FOG LIGHT RIGHT | | | 38 | BN-GN | 0,75mm² | | REAR FOG LIGHT RIGHT | | ||
Zeile 80: | Zeile 80: | ||
| 65 | BK-GN | 1,50mm² | | POWER GND | | | 65 | BK-GN | 1,50mm² | | POWER GND | | ||
| 66 | | 0,50mm² | | TURN INDICATOR FRONT RIGHT | | | 66 | | 0,50mm² | | TURN INDICATOR FRONT RIGHT | | ||
- | | 67 | | 0,50mm² | | | | + | | 67 | WH-VT | 0,50mm² | FUEL FLAP UNLOCK RELAY | | |
- | | 68 | GY | 0,50mm² | | ABS_YAW_ACC_PEDAL | + | | 68 | GY-VT | 0,50mm² | | FUEL FLAP LOCK RELAY | |
| 69 | GN-OG | | | TURN INDICATION REAR RIGHT | | | 69 | GN-OG | | | TURN INDICATION REAR RIGHT | | ||
| 70 | BN-GN | | | INTERIOR LIGHT | | | 70 | BN-GN | | | INTERIOR LIGHT | | ||
- | | 71 | GY-VT | 1, | + | | 71 | | | | | |
| 72 | | | | | | | 72 | | | | | | ||
| 73 | GN-BN | 1,00mm² | | REVERSE LIGHT SUPPLY LEFT | | | 73 | GN-BN | 1,00mm² | | REVERSE LIGHT SUPPLY LEFT | | ||
Zeile 90: | Zeile 90: | ||
| 75 | | | | | | | 75 | | | | | | ||
| 76 | YE-OG | 1,50mm² | | KL15 RELAY SUPPLY EJB | | | 76 | YE-OG | 1,50mm² | | KL15 RELAY SUPPLY EJB | | ||
