artikel:nav_common:omap5948:start [Wed. 24.07.2019 10:47] – go4it | artikel:nav_common:omap5948:start [Sat. 25.07.2020 12:03] – [Der DSP (Digital-Signal-Processor)] go4it | ||
Zeile 34: | Zeile 34: | ||
Der DSP ist ein '' | Der DSP ist ein '' | ||
+ | ===== Memory Map ===== | ||
+ | | 0x0000 0000 | 0x01FF FFFF | (32 MB) | Flash | | ||
+ | | 0x2000 0000 | 0x2000 FFFF | |internal SRAM of OMAP | | ||
+ | | 0x8000 0000 | 0xEFFF FFFF | | external SDRAM | | ||
+ | | 0xFFFE 0000 | 0xFFFF FFFFF | | Memory mapped registers | | ||
===== Anbindung des Flash-Speicher ===== | ===== Anbindung des Flash-Speicher ===== | ||
Zeile 39: | Zeile 46: | ||
Über das '' | Über das '' | ||
+ | CS0 and CS3 address decoding (address in the TC memory mapping) can be swapped through the BM bit field in the EMIFS global control register. When the BM bit field is set, CS3 is activated in the 0000: | ||
+ | The BM bit is sampled at reset depending on two factors. If MPU_BOOT (ball J20) is 1 and the device type is emulation then BM resets to 1. Otherwise, BM resets to 0. | ||
+ | Thus, the boot is executed from CS0 or from CS3 attached memories. During normal execution, BM can be changed dynamically but obvious software precautions are required to prevent system crash. | ||
===== Anbindung des SDRAM ===== | ===== Anbindung des SDRAM ===== | ||
+ | Das SD-RAM liegt dann im Adressbereich '' | ||
===== Das JTAG-Interface ===== | ===== Das JTAG-Interface ===== | ||
Zeile 48: | Zeile 61: | ||
JTAG_CHAIN = 8, 4, 38 ; list of IR lenghts of all TAP controller in JTAG chain | JTAG_CHAIN = 8, 4, 38 ; list of IR lenghts of all TAP controller in JTAG chain | ||
+ | - TotalIRLen = 50, IRPrint = 0x001444035F5D81 | ||
+ | - JTAG chain detection found 3 devices: | ||
===== Technische Daten ===== | ===== Technische Daten ===== | ||
Zeile 55: | Zeile 76: | ||
* Hersteller: TI (Texas Instruments) | * Hersteller: TI (Texas Instruments) | ||
+ | * Praktisch baugleich mit OMAP5912 und OMAP1621, OMAP1611b (zzgl. ein paar " | ||
+ | * MCU-Familie: | ||
+ | * Erscheinungsjahr: | ||
+ | * CPU: ARM926EJ-S | ||
+ | * DSP: C55x | ||
