artikel:nav_common:pin_code_calculator [Sat. 23.11.2019 15:18] – go4it | artikel:nav_common:pin_code_calculator [Sun. 16.10.2022 15:59] – go4it |
====== PIN-Code Calculator ====== | ~~NOCACHE~~ |
| ====== Ford Radio PIN-Code Calculator (EX, FX, NX, MCA, CD6000, and others..) ====== |
//Dieses Tool dient dazu den Radio PIN anhand der Seriennummer zu berechnen, falls dieser verloren gegangen ist.// | //Dieses Tool dient dazu den Radio-PIN anhand der Seriennummer zu berechnen (z.B. wenn sie nicht mehr auffindbar ist)// |
{{:artikel:nav_fx:navi-fx_typenschild.jpg?320&nolink|}} | ===== Code-Generator ===== |
<html> | <html> |
<tr> | <tr> |
<td> | <td> |
<label for="type">Enter Type:</label> | <label for="type">Type:</label> |
</td> | </td> |
<td> | <td> |
<input type="text" name="type" id="type" minlength="10" maxlength="13" ><br/> | <input type="text" name="type" id="type" minlength="10" maxlength="13" ><br/> |
<div style="font-size: 0.8em; color:#A0A0A0;">Example: 7 612 300 524</div> | <div style="font-size: 0.8em; color:#A0A0A0;">Example: '7 612 300 524' or 'V' for V-Serials, or 'M' for M-Serials.</div> |
</td> | </td> |
</tr> | </tr> |
<tr> | <tr> |
<td> | <td> |
<label for="serial">Enter Serial:</label> | <label for="serial">Serial:</label> |
</td> | </td> |
<td> | <td> |
<input type="text" name="serial" id="serial" minlength="7" maxlength="7"><br/> | <input type="text" name="serial" id="serial" minlength="7" maxlength="7"><br/> |
<div style="font-size: 0.8em; color:#A0A0A0;">Example: 9083560</div> | <div style="font-size: 0.8em; color:#A0A0A0;">Example: '9083560'</div> |
</td> | </td> |
</tr> | </tr> |
jQuery('#pin_code').val(data['data']); | jQuery('#pin_code').val(data['data']); |
} else if (data['result'] == 'ERROR') { | } else if (data['result'] == 'ERROR') { |
jQuery('#pin_code').val('----'); | jQuery('#pin_code').val('XXXX'); |
alert(data['message']); | alert(data['message']); |
</html> | </html> |
| :i: Bei Eingabe einer nicht unterstützten Type erscheint eine Fehlermeldung "Unknown algorithm ...". |
| //{{counter}} person(s) visited this page until now.// |
| ===== Gerätetyp und Seriennummer ermitteln ===== |
| ==== Mit ELMConfig ohne Ausbau ermitteln ==== |
| Den Gerätetype und die Seriennummer kann man auch mit Hilfe eines [[artikel:nav_common:navi_serial_readout_elm|ELM-Adapters und ELM-Config auslesen]]. |
| ==== Ablesen vom Typenschild ==== |
| ^ Gerätetyp ^ Typenschild ^ Hinweise zur Verwendung im Code-Generator ^ |
| ^ Navigationssystem FX, NX, MCA \\ {{:artikel:nav_fx:navi-fx_kartenansicht.jpg?nolink&160|}} \\ {{:artikel:nav_nx:navi_nx.jpg?nolink&160|}} \\ {{:artikel:nav_mca:mca_front.jpg?nolink&160|}} | {{:artikel:nav_fx:navi-fx_typenschild.jpg?240&nolink|}} | Bei FX, NX und MCA beide Werte eintragen | |
| ^ Navigationssystem FX, NX, MCA **"X-Part"** | {{:artikel:nav_common:fx_x-part.png?240|}} | Die "360" in der Typennummer durch "300" ersetzen! | |
| ^ Ford 6000CD, Ford Sony, Nav EX \\ {{:artikel:radio_6000cd:ford_6000cd.jpg?nolink&160|}} \\ {{:artikel:radio_sony:sony_radio.jpg?nolink&160|}} \\ {{:artikel:audio_navigation:navi_ex:navi-ex_cd.jpg?direct&160|}} | {{:artikel:nav_common:6000cd_fl_type_serial.png?direct&240|}} \\ {{:artikel:nav_common:v-code_example.jpg?nolink&240|}} | "V" in das Feld "Type" und nur die Ziffern in "Serial" eintragen | |
| ^ Ford 6000CD (Visteon) \\ {{:artikel:nav_common:6000cd_97ap-18c815-ha_front.jpg?direct&160|}} | {{:artikel:nav_common:6000cd_label_type_serial.png?direct&240|}} | "M" in das Feld "Type" und nur die Ziffern in "Serial" eintragen | |
