grundlagen:sicherungskasten_motorraum:fl [Thu. 15.02.2018 06:59] – wikiadmin | artikel:sicherungskasten_motorraum:fl [Sun. 25.11.2018 11:22] – ↷ Links angepasst weil Seiten im Wiki verschoben wurden 95.216.157.240 | ||
===== Sicherungen im Motorraum (FL) ====== | ===== Sicherungen im Motorraum (FL) ====== | ||
- | {{grundlagen: | + | {{artikel: |
- | ^ Fuse | Ampere | + | ^ Name | Ampere | Bezeichnung | Absicherung von ... | |
- | ^ F1 | 10 | Transmission control module (AWF21) | | + | ^ F1 | 10 | |
- | ^ F1 | 15 | Transmission control module (MPS6) | | + | ^ F1 | 15 | |
- | ^ F2 | 5 | Glow plug monitoring (diesel engines) | | + | ^ F2 | |
- | ^ F2 | 5 | Vaporiser glow plug monitoring (2.0L Duratorq-TDCi Stage V and 2.2L Duratorq-TDCi Stage V) | | + | ^ F2 | |
- | ^ F3 | 80 | Electric hydraulic power steering (EHPAS) (1.6L Duratec-16V Ti-VCT Stage V, 1.6L EcoBoost SCTi, 2.0L EcoBoost SCTi, 1.6L Duratorq-TDCi Stage V and 2.0L Duratorq-TDCi Stage V) | | + | ^ F3 | 80 | |
- | ^ F4 | 60 | Glow plugs | | + | ^ F4 | 60 | |
- | ^ F5 | 60 | Engine cooling fan (1.6L Duratorq-TDCi, | + | ^ F5 | 60 | |
- | ^ F5 | 70 | Engine cooling fan – twin fan (1.6L EcoBoost SCTi) | | + | ^ F5 | 70 | |
- | ^ F6 | 7,5 | HEGO sensor (1.6L Duratorq-TDCi) | | + | ^ F6 | 7,5 | |
- | ^ F6 | 10 | HEGO sensors 1, CMS sensor, Oxygen sensor (engine management) | | + | ^ F6 | 10 | |
- | ^ F6 | 20 | Vaporiser glow plug (2.0L Duratorq-TDCi Stage V, 2.2L Duratorq-TDCi Stage V) | | + | ^ F6 | 20 | |
- | ^ F7 | 5 | Relay coils | | + | ^ F7 | |
- | ^ F8 | 10 | Powertrain control module, Fuel metering unit, MAF sensor, fuel rail pressure control valve (engine management). | | + | ^ F8 | 10 | |
- | ^ F8 | 20 | Powertrain control module (2.0L EcoBoost SCTi and 2.0L Duratorq-TDCi Stage V) | | + | ^ F8 | 20 | |
- | ^ F8 | 15 | Powertrain control module (1.6L EcoBoost SCTi, 1.6L Duratorq-TDCi and 2.2L Duratorq-TDCi Stage V) | | + | ^ F8 | 15 | |
- | ^ F9 | 10 | MAF Sensor, Fuel Injectors, Variable Intake Valve, Variable Exhaust Valve, ignition coils (engine management) | | + | ^ F9 | 10 | |
- | ^ F9 | 5 | Fuel pump vaporiser (2.0L Duratorq-TDCi Stage V) | | + | ^ F9 | |
- | ^ F9 | 7,5 | MAF Sensor, EGR bypass Valve , Fuel pump vaporiser (2.2L Duratorq-TDCi Stage V) (engine management) | | + | ^ F9 | 7,5 | |
- | ^ F9 | 7,5 | Heated oxygen (HEGO) sensors (Petrol engines) | | + | ^ F9 | 7,5 | |
- | ^ F9 | 7,5 | Degas valve, TMAF sensor, active grille shutter, bypass valve, relay coil, auxiliary run on, water pump (1.6L EcoBoost SCTi) | | + | ^ F9 | 7,5 | |
- | ^ F10 | 10 | Engine control module (2.0L Duratorq-TDCi, | + | ^ F10 | 10 | |
- | ^ F10 | 7,5 | Auxiliary run on, water pump (1.6L EcoBoost SCTi) | | + | ^ F10 | 7,5 || Auxiliary run on, water pump (1.6L EcoBoost SCTi) | |
- | ^ F11 | 10 | PCV Valve, VCV Valve, Water in Fuel Sensor, Sonic Purge Valve, Swirl Control Valve, Variable Intake Valve, EGR Valve, IVVT Oil Control Valve (engine management). T.MAF sensor, variable exhaust timing valve, active grille shutter, cannister purge valve, turbo control valve, waste gate valve (engine management) | | + | ^ F11 | 10 | |
- | ^ F11 | 10 | Turbo control valve, MAF sensor, active grille shutter, EGR valve, VCV valve (1.6L Duratorq-TDCi) | | + | ^ F11 | 10 | |
- | ^ F11 | 5 | MAF sensor, Water in Fuel Sensor, Active grille shutter, inlet metering valve (2.0L Duratorq-TDCi Stage V). | | + | ^ F11 | |
- | ^ F11 | 7,5 | Fuel rail pressure, fuel metering unit, fuel pump vaporiser, active grille shutter (2.2L Duratorq-TDCi Stage V | | + | ^ F11 | 7,5 | |
- | ^ F11 | 10 | Turbo control valve, variable intake timing valve, variable exhaust timing valve, cannister purge valve, electrical bypass valve (1.6L EcoBoost SCTi). | | + | ^ F11 | 10 | |
- | ^ F12 | 15 | Ignition coils (1.6L EcoBoost SCTi and 2.0L EcoBoost SCTi) | | + | ^ F12 | 15 | |
- | ^ F12 | 10 | Coil on Plug; Canister Purge Valve, Power Steering Pressure Switch (engine management) | | + | ^ F12 | 10 | |
- | ^ F12 | 10 | EGR throttle, variable turbo control (2.0L Duratorq-TDCi) | | + | ^ F12 | 10 | |
- | ^ F12 | 5 | Relay coils (2.0L Duratorq-TDCi Stage V, 2.2L Duratorq-TDCi Stage V and 1.6L Duratorq-TDCi) | | + | ^ F12 | |
- | ^ F13 | 15 | Air conditioning | | + | ^ F13 | 15 | |
- | ^ F14 | 15 | Diesel filter heater (2.0L Duratorq-TDCi, | + | ^ F14 | 15 | |
- | ^ F14 | 10 | HEGO sensor (2.2L Duratorq-TDCi Stage V) | | + | ^ F14 | 10 | |
- | ^ F15 | 40 | Starter relay | | + | ^ F15 | 40 | |
- | ^ F16 | 80 | Diesel auxiliary heater (PTC) | | + | ^ F16 | 80 | |
- | ^ F17 | 60 | Central fuse box supply | + | ^ F17 | 60 | KL30 SUPPLY |
- | ^ F18 | 60 | Central fuse box supply | + | ^ F18 | 60 | KL30 SUPPLY |
- | ^ F19 | 60 | Rear fuse box supply C | | + | ^ F19 | 60 | |
- | ^ F20 | 60 | Rear fuse box supply D | | + | ^ F20 | 60 | |
- | ^ F21 | 30 | VQM/non VQM: Cluster/ | + | ^ F21 | 30 | |
- | ^ F22 | 30 | Windscreen wiper module | | + | ^ F22 | 30 | |
- | ^ F23 | 30 | Heated rear window | | + | ^ F23 | 30 | |
- | ^ F24 | 30 | Headlamp washer | | + | ^ F24 | 30 | |
- | ^ F25 | 30 | ABS valves | | + | ^ F25 | 30 | |
- | ^ F26 | 40 | ABS pump | | + | ^ F26 | 40 | |
- | ^ F27 | 25 | Fuel fired heater | | + | ^ F27 | 25 | |
- | ^ F28 | 40 | Heater blower | | + | ^ F28 | 40 | |
- | ^ F29 | — | Not used | | + | ^ F29 | — |
- | ^ F30 | 5 | ABS 30 feed | | + | ^ F30 | |
- | ^ F31 | 15 | Horn | | + | ^ F31 | 15 | |
- | ^ F32 | 5 | Fuel fired heater – remote control | | + | ^ F32 | |
- | ^ F33 | 5 | Light switch module, engine compartment fuse box coils | | + | ^ F33 | |
- | ^ F34 | 40 | Heated windscreen (left-hand side) | | + | ^ F34 | 40 | |
- | ^ F35 | 40 | Heated windscreen (right-hand side) | | + | ^ F35 | 40 | |
- | ^ F36 | 15 | Rear wiper 15 feed | | + | ^ F36 | 15 | |
- | ^ F37 | 7,5 | Heated front washer jets/FLR + FSM KL15 | | + | ^ F37 | 7,5 | |
- | ^ F38 | 10 | PCM/ | + | ^ F38 | 10 | |
- | ^ F39 | 15 | Adaptive front lighting system (AFS) | | + | ^ F39 | 15 | |
- | ^ F40 | 5 | Headlamp levelling / AFS module | | + | ^ F40 | |
- | ^ F41 | 20 | Instrument panel | | + | ^ F41 | 20 | |
- | ^ F42 | 5 | Cluster IP | | + | ^ F42 | |
- | ^ F43 | 15 | Audio/BVC module/DAB module | | + | ^ F43 | 15 | |
- | ^ F44 | 5 | Automatic AC / Manual AC | | + | ^ F44 | |
- | ^ F45 | 5 | FLR (Start Stop) | | + | ^ F45 | |
^ Relay | Protected components | | ^ Relay | Protected components | |
