artikel:sicherungen:motorraum_fl [Sun. 16.08.2020 18:42] – go4it | artikel:sicherungen:motorraum_fl [Tue. 11.05.2021 10:57] (aktuell) – go4it | ||
- | ===== Sicherungen | + | ===== Sicherungskasten |
+ | ==== Sicherungen ==== | ||
^ Name | Ampere | Bezeichnung | Absicherung von ... | | ^ Name | Ampere | Bezeichnung | Absicherung von ... | | ||
Zeile 14: | Zeile 15: | ||
^ F5 | 60 | | Engine cooling fan (1.6L Duratorq-TDCi, | ^ F5 | 60 | | Engine cooling fan (1.6L Duratorq-TDCi, | ||
^ F5 | 70 | | Engine cooling fan – twin fan (1.6L EcoBoost SCTi) | | ^ F5 | 70 | | Engine cooling fan – twin fan (1.6L EcoBoost SCTi) | | ||
- | ^ F6 | 7,5 | | HEGO sensor (1.6L Duratorq-TDCi) | | + | ^ F6 | 7,5 | | HEGO sensor (1.6L Duratorq-TDCi) | |
^ F6 | 10 | | HEGO sensors 1, CMS sensor, Oxygen sensor (engine management) | | ^ F6 | 10 | | HEGO sensors 1, CMS sensor, Oxygen sensor (engine management) | | ||
^ F6 | 20 | | Vaporiser glow plug (2.0L Duratorq-TDCi Stage V, 2.2L Duratorq-TDCi Stage V) | | ^ F6 | 20 | | Vaporiser glow plug (2.0L Duratorq-TDCi Stage V, 2.2L Duratorq-TDCi Stage V) | | ||
Zeile 23: | Zeile 24: | ||
^ F9 | 10 | | MAF Sensor, Fuel Injectors, Variable Intake Valve, Variable Exhaust Valve, ignition coils (engine management) | | ^ F9 | 10 | | MAF Sensor, Fuel Injectors, Variable Intake Valve, Variable Exhaust Valve, ignition coils (engine management) | | ||
^ F9 | 5 | | Fuel pump vaporiser (2.0L Duratorq-TDCi Stage V) | | ^ F9 | 5 | | Fuel pump vaporiser (2.0L Duratorq-TDCi Stage V) | | ||
- | ^ F9 | 7,5 | | MAF Sensor, EGR bypass Valve , Fuel pump vaporiser (2.2L Duratorq-TDCi Stage V) (engine management) | | + | ^ F9 | 7,5 | | MAF Sensor, EGR bypass Valve , Fuel pump vaporiser (2.2L Duratorq-TDCi Stage V) (engine management) | |
- | ^ F9 | 7,5 | | Heated oxygen (HEGO) sensors (Petrol engines) | | + | ^ F9 | 7,5 | | Heated oxygen (HEGO) sensors (Petrol engines) | |
- | ^ F9 | 7,5 | | Degas valve, TMAF sensor, active grille shutter, bypass valve, relay coil, auxiliary run on, water pump (1.6L EcoBoost SCTi) | | + | ^ F9 | 7,5 | | Degas valve, TMAF sensor, active grille shutter, bypass valve, relay coil, auxiliary run on, water pump (1.6L EcoBoost SCTi) | |
^ F10 | 10 | | Engine control module (2.0L Duratorq-TDCi, | ^ F10 | 10 | | Engine control module (2.0L Duratorq-TDCi, | ||
- | ^ F10 | 7,5 | + | ^ F10 | 7,5 | | Auxiliary run on, water pump (1.6L EcoBoost SCTi) | |
^ F11 | 10 | | PCV Valve, VCV Valve, Water in Fuel Sensor, Sonic Purge Valve, Swirl Control Valve, Variable Intake Valve, EGR Valve, IVVT Oil Control Valve (engine management). T.MAF sensor, variable exhaust timing valve, active grille shutter, cannister purge valve, turbo control valve, waste gate valve (engine management) | | ^ F11 | 10 | | PCV Valve, VCV Valve, Water in Fuel Sensor, Sonic Purge Valve, Swirl Control Valve, Variable Intake Valve, EGR Valve, IVVT Oil Control Valve (engine management). T.MAF sensor, variable exhaust timing valve, active grille shutter, cannister purge valve, turbo control valve, waste gate valve (engine management) | | ||
^ F11 | 10 | | Turbo control valve, MAF sensor, active grille shutter, EGR valve, VCV valve (1.6L Duratorq-TDCi) | | ^ F11 | 10 | | Turbo control valve, MAF sensor, active grille shutter, EGR valve, VCV valve (1.6L Duratorq-TDCi) | | ||
^ F11 | 5 | | MAF sensor, Water in Fuel Sensor, Active grille shutter, inlet metering valve (2.0L Duratorq-TDCi Stage V). | | ^ F11 | 5 | | MAF sensor, Water in Fuel Sensor, Active grille shutter, inlet metering valve (2.0L Duratorq-TDCi Stage V). | | ||
- | ^ F11 | 7,5 | | Fuel rail pressure, fuel metering unit, fuel pump vaporiser, active grille shutter (2.2L Duratorq-TDCi Stage V | | + | ^ F11 | 7,5 | | Fuel rail pressure, fuel metering unit, fuel pump vaporiser, active grille shutter (2.2L Duratorq-TDCi Stage V | |
^ F11 | 10 | | Turbo control valve, variable intake timing valve, variable exhaust timing valve, cannister purge valve, electrical bypass valve (1.6L EcoBoost SCTi). | | ^ F11 | 10 | | Turbo control valve, variable intake timing valve, variable exhaust timing valve, cannister purge valve, electrical bypass valve (1.6L EcoBoost SCTi). | | ||
^ F12 | 15 | | Ignition coils (1.6L EcoBoost SCTi and 2.0L EcoBoost SCTi) | | ^ F12 | 15 | | Ignition coils (1.6L EcoBoost SCTi and 2.0L EcoBoost SCTi) | | ||
Zeile 42: | Zeile 43: | ||
^ F15 | 40 | | Starter relay | | ^ F15 | 40 | | Starter relay | | ||
^ F16 | 80 | | Diesel auxiliary heater (PTC) | | ^ F16 | 80 | | Diesel auxiliary heater (PTC) | | ||
- | ^ F17 | 60 | KL30 SUPPLY A | KL30-Zuleitung " | + | ^ F17 | 60 | '' |
- | ^ F18 | 60 | KL30 SUPPLY B | KL30-Zuleitung " | + | ^ F18 | 60 | '' |
^ F19 | 60 | | Rear fuse box supply C | | ^ F19 | 60 | | Rear fuse box supply C | | ||
^ F20 | 60 | | Rear fuse box supply D | | ^ F20 | 60 | | Rear fuse box supply D | | ||
Zeile 62: | Zeile 63: | ||
^ F35 | 40 | | Heated windscreen (right-hand side) | | ^ F35 | 40 | | Heated windscreen (right-hand side) | | ||
^ F36 | 15 | | Rear wiper 15 feed | | ^ F36 | 15 | | Rear wiper 15 feed | | ||
- | ^ F37 | 7,5 | | Heated front washer jets/FLR + FSM KL15 | | + | ^ F37 | 7,5 | | Heated front washer jets/FLR + FSM KL15 | |
^ F38 | 10 | | PCM/ | ^ F38 | 10 | | PCM/ | ||
^ F39 | 15 | | Adaptive front lighting system (AFS) | | ^ F39 | 15 | | Adaptive front lighting system (AFS) | | ||
Zeile 72: | Zeile 73: | ||
^ F45 | 5 | | FLR (Start Stop) | | ^ F45 | 5 | | FLR (Start Stop) | | ||
- | ^ Relay | Protected components | | + | ==== Relais ==== |
- | ^ R1 | Starter relay | | + | |
- | ^ R2 | PCM relay | | + | ^ Relay | Protected components |
- | ^ R3 | Air conditioning clutch relay | | + | ^ R1 | Starter relay | |
- | ^ R4 | Glow plug relay (Diesel engines); Degas valve (1.6 Duratec-16V Ti-VCT) | | + | ^ R2 | PCM relay | | 6G9T-14B192-AA |
- | ^ R5 | Cooling fan relay | | + | ^ R3 | Air conditioning clutch relay | |
- | ^ R6 | Heated windscreen | + | ^ R4 | Glow plug relay (Diesel engines); Degas valve (1.6 Duratec-16V Ti-VCT) |
- | ^ R7 | 15 relay | | + | ^ R5 | Cooling fan relay | |
- | ^ R8 | Windscreen wiper intermittent wipe relay | | + | ^ R6 | Heated windscreen |
- | ^ R9 | Horn relay | | + | ^ R7 | 15 relay | |
- | ^ R10 | Headlamp washer pump relay | | + | ^ R8 | Windscreen wiper intermittent wipe relay | |
- | ^ R11 | Windscreen wiper on/off relay | | + | ^ R9 | Horn relay | |
- | ^ R12 | Auto Trans Startlock relay | | + | ^ R10 | Headlamp washer pump relay | |
+ | ^ R11 | Windscreen wiper on/off relay | | ||
+ | ^ R12 | Auto Trans Startlock relay | | ||
