artikel:can-bus:mk4_can-bus_modules [Wed. 08.03.2023 11:49] – go4it | artikel:can-bus:mk4_can-bus_modules [Wed. 08.03.2023 13:07] – go4it | ||
Zeile 2: | Zeile 2: | ||
^ CAN-BUS ^ Modul ^ UDS-ID ^ Modulbezeichnung ^ | ^ CAN-BUS ^ Modul ^ UDS-ID ^ Modulbezeichnung ^ | ||
+ | | HS-CAN | IPMA | 0x706 | Image Processing Module " | ||
| HS-CAN | BCM | 0x726 | Body Control Module | | | HS-CAN | BCM | 0x726 | Body Control Module | | ||
| HS-CAN | PSCM | 0x730 | Power Steering Control Module | | | HS-CAN | PSCM | 0x730 | Power Steering Control Module | | ||
Zeile 10: | Zeile 11: | ||
| HS-CAN | CCM | 0x764 | Cruise Control Module | | | HS-CAN | CCM | 0x764 | Cruise Control Module | | ||
| HS-CAN | SASM | 0x797 | Steering Angle Sensor Module | | | HS-CAN | SASM | 0x797 | Steering Angle Sensor Module | | ||
+ | | HS-CAN | SCCM | | Steering Column Control Module | | ||
| HS-CAN | PCM | 0x7E0 | Powertrain Control Module | | | HS-CAN | PCM | 0x7E0 | Powertrain Control Module | | ||
| HS-CAN | TCM | 0x7E1 | Transmission Control Module | | | HS-CAN | TCM | 0x7E1 | Transmission Control Module | | ||
Zeile 15: | Zeile 17: | ||
| HS-CAN | KVM | | Keyless Vehicle Module | | | HS-CAN | KVM | | Keyless Vehicle Module | | ||
- | | MS-CAN | IPMA | 0x706 | Image Processing Module " | ||
| MS-CAN | IPC | 0x720 | Intrument Panel Cluster | | | MS-CAN | IPC | 0x720 | Intrument Panel Cluster | | ||
| MS-CAN | BCM | 0x726 | Body Control Module | | | MS-CAN | BCM | 0x726 | Body Control Module | |
