artikel:can-bus:mk4_can-bus_modules [Wed. 08.03.2023 11:59] – go4it | artikel:can-bus:mk4_can-bus_modules [Wed. 08.03.2023 13:07] – go4it | ||
Zeile 11: | Zeile 11: | ||
| HS-CAN | CCM | 0x764 | Cruise Control Module | | | HS-CAN | CCM | 0x764 | Cruise Control Module | | ||
| HS-CAN | SASM | 0x797 | Steering Angle Sensor Module | | | HS-CAN | SASM | 0x797 | Steering Angle Sensor Module | | ||
+ | | HS-CAN | SCCM | | Steering Column Control Module | | ||
| HS-CAN | PCM | 0x7E0 | Powertrain Control Module | | | HS-CAN | PCM | 0x7E0 | Powertrain Control Module | | ||
| HS-CAN | TCM | 0x7E1 | Transmission Control Module | | | HS-CAN | TCM | 0x7E1 | Transmission Control Module | |
