artikel:can-bus:mk4_can-bus_modules [Tue. 09.04.2019 20:13] – go4it | artikel:can-bus:mk4_can-bus_modules [Wed. 08.03.2023 13:07] – go4it | ||
- | ====== CAN-Bus Module im MK4 ====== | + | ====== |
^ CAN-BUS ^ Modul ^ UDS-ID ^ Modulbezeichnung ^ | ^ CAN-BUS ^ Modul ^ UDS-ID ^ Modulbezeichnung ^ | ||
- | | HS-CAN | ABS | + | | HS-CAN | IPMA | 0x706 | Image Processing Module " |
- | | HS-CAN | ACC | | Adaptive Cruise Control | + | |
| HS-CAN | BCM | 0x726 | Body Control Module | | | HS-CAN | BCM | 0x726 | Body Control Module | | ||
- | | HS-CAN | CCM | 0x764 | Cruise Control Module | | ||
- | | HS-CAN | HCM | 0x734 | Headlight Control Module | | ||
- | | HS-CAN | KVM | | Keyless Vehicle Module | | ||
- | | HS-CAN | OBD | 0x72E | On-Board-Diagnose | | ||
- | | HS-CAN | PCM | 0x7E0 | Powertrain Control Module | | ||
| HS-CAN | PSCM | 0x730 | Power Steering Control Module | | | HS-CAN | PSCM | 0x730 | Power Steering Control Module | | ||
| HS-CAN | RCM | 0x737 | Restraints Control Module | | | HS-CAN | RCM | 0x737 | Restraints Control Module | | ||
+ | | HS-CAN | OBD | 0x72E | On-Board-Diagnose | | ||
+ | | HS-CAN | HCM | 0x734 | Headlight Control Module | | ||
+ | | HS-CAN | ABS | 0x760 | Anti-lock Braking System | | ||
+ | | HS-CAN | CCM | 0x764 | Cruise Control Module | | ||
| HS-CAN | SASM | 0x797 | Steering Angle Sensor Module | | | HS-CAN | SASM | 0x797 | Steering Angle Sensor Module | | ||
+ | | HS-CAN | SCCM | | Steering Column Control Module | | ||
+ | | HS-CAN | PCM | 0x7E0 | Powertrain Control Module | | ||
| HS-CAN | TCM | 0x7E1 | Transmission Control Module | | | HS-CAN | TCM | 0x7E1 | Transmission Control Module | | ||
- | | MS-CAN | AHCM | 0x7E3 | Auxiliary Heater Control | | + | | HS-CAN | ACC |
- | | MS-CAN | BCM | + | | HS-CAN | KVM |
- | | MS-CAN | DDM | 0x740 | Driver Door Module | | + | ^ ^^^^ |
- | | MS-CAN | DSM | + | |
- | | MS-CAN | EATC | 0x733 | Electronic Automatic Temperature Control | | + | |
| MS-CAN | IPC | 0x720 | Intrument Panel Cluster | | | MS-CAN | IPC | 0x720 | Intrument Panel Cluster | | ||
- | | MS-CAN | IPMA | 0x706 | Image Processing | + | | MS-CAN | BCM |
| MS-CAN | KVM | 0x731 | Keyless Vehicle Module | | | MS-CAN | KVM | 0x731 | Keyless Vehicle Module | | ||
+ | | MS-CAN | EATC | 0x733 | Electronic Automatic Temperature Control | | ||
| MS-CAN | PAM | 0x736 | Parking Aid Module | | | MS-CAN | PAM | 0x736 | Parking Aid Module | | ||
- | | MS-CAN | PDM | 0x741 | Passenger Door Module | | ||
| MS-CAN | RCM | 0x737 | Restraints Control Module | | | MS-CAN | RCM | 0x737 | Restraints Control Module | | ||
+ | | MS-CAN | DDM | 0x740 | Driver Door Module | | ||
+ | | MS-CAN | PDM | 0x741 | Passenger Door Module | | ||
| MS-CAN | SODL | 0x7C4 | Side Obstacle Detection Control Module Left | | | MS-CAN | SODL | 0x7C4 | Side Obstacle Detection Control Module Left | | ||
| MS-CAN | SODR | 0x7C6 | Side Obstacle Detection Control Module Right | | | MS-CAN | SODR | 0x7C6 | Side Obstacle Detection Control Module Right | | ||
+ | | MS-CAN | AHCM | 0x7E3 | Auxiliary Heater Control | | ||
+ | | MS-CAN | DSM | | Driver Seat Module | | ||
| MS-CAN | TRM | | Trailer Module | | | MS-CAN | TRM | | Trailer Module | | ||
- | | MM-CAN | ACM | + | ^ ^^^^ |
- | | MM-CAN | CDDJ | 0x770 | | | + | | MM-CAN | IPC |
- | | MM-CAN | IPC | + | | MM-CAN | ACM |
+ | | MM-CAN | CDDJ | 0x770 | CD-Changer | ||
| MM-CAN | SRM | 0x772 | Speech Recognition System | | | MM-CAN | SRM | 0x772 | Speech Recognition System | | ||
